I applied a normalize audio to my sequence. Now I want to remove it. How can I unapply it?
And it's not destructive to the original clip, is it?
Yeah, I can't Ctrl-z it unless I want to go back 200 steps.
Why is this not applied as effects are? Why can't you tick it on and off?
How about re-normalizing it back to 0db? Will that work?
Seems to me that normalizing audio is a very dangerous thing to play with if you can never undo it later on down the road.
Why cant you go back to the original sound clips?
And do what? Replace them with the originals?
I have a sequence with several hundred clips in it. The normalize audio was applied to the whole sequence, so I'm assuming it did its thing on all the clips. It would be a disaster to have to relink all those again if that's what needs to be done.
Fortunately I'm a habitual incremental saver, so I was able to find a previous version that was pre-normalized. I imported that sequence into my current project and the problem is solved. But if I hadn't had that saved version, I would be a little upset.
Now I know. Don't use normalize ever.
