fabio.bozzo
CF10 web services not "invokable" from CF9
Jul 12, 2012 1:28 AM
Tags: #wsdl #webservice #upgrade #exception #cf9 #cf10 #cfinvoke
Here's my situation:
1. first server with CF10 (just upgraded) running an application with this CFC making a wsdl web service:
<cffunction name="myWS" access="remote" returntype="boolean" output="false">
      <!--- stuff.... --->
</cffunction>
2. second server with CF9.0.1 (last hotfixes) running the web service invocation like this:
<cfinvoke webservice="http://www.firstserversite.xxx/api/folder/mycomp.cfc?wsdl" method="myWS" returnvariable="LOCAL.ret">
       <cfinvokeargument name="xxx" value="#xxx#" />
</cfinvoke>
Before upgrading first server to CF10, my two application servers talked each other the right way and that was working.
Now I see this error:
"Cannot generate stub objects for web service invocation"
ERROR: Missing <soap:fault> element inFault
It sounds like WSDL generated by cf10 is not compatible with what cf9-cfinvoke does expect!
How can I workaround this?
Many thanks to you, it's very urgent!!
    Jul 12, 2012 5:19 AM   in reply to fabio.bozzo
    The WSDL and Axis versions of ColdFusion 10 are higher than those of ColdFusion 9. That may be the cause. If so, follow the recommendation of the document 'Web service enhancements in ColdFusion 10', and replace ?wsdl in the URL with ?wsdl2
    Jul 20, 2012 6:11 PM   in reply to fabio.bozzo
    Hi Fabio,
    Did you find a solution to this problem?
    I'm having a very similar issue with CF10. After upgrading from CF8 to CF10 the ?wsdl requests appear to be failing with http500 errors.
    Fortunately these services are consumed from the client side and are still working from that perspective.
    Brett
    B)
    Jul 21, 2012 12:44 AM   in reply to BrettPR
    BrettPR wrote:
    Hi Fabio,
    As I said, one solution may be to replace ?wsdl in the URL with ?wsdl2
    Oct 21, 2012 2:54 AM   in reply to fabio.bozzo
    Could the first bug referenced on this page have a hand in this:
    http://helpx.adobe.com/coldfusion/kb/coldfusion-10-update-3.html
    3321512
    Web Services defaults to Axis 2 methods despite setting the Axis version to Axis 1 in ColdFusion Administrator.
    Sounds like CF10 only serves-up Axis 2 web services rather than serving up v1 ones when it's told to?
    Sadly 10.0.3 has been pulled due to it being buggy, but there should be a replacement soon.
    Adam
