Blue tilde over an imported character
Jul 20, 2012 9:24 AM
I imported a Word doc to InD CS3 that has some font changes to the SymbolPropBT TTF font.
In Design is displaying the minus sign from the font with a blue tilde over it. The character has the correct dimensions and appears to be OK in InD (except for the tilde) and in PDF.
HOWEVER, InD doesn't find that character when its searched, Acrobat also can't find it. If I simply change to that font and type a hyphen, it is found in InDesign and in Acrobat.
What does the blue tilde signify?
Ken
    Jul 20, 2012 9:33 AM   in reply to Ken Krugh
    Screen shot please...
    Is this blue tilde visible when non-printing characters are hidden?
    Jul 20, 2012 10:21 AM   in reply to Ken Krugh
    With just the character selected, what does the Info panel display as its Unicode?
    (I'm thinking it works just like spaces -- ID knows lots of them, but to a font they all appear as a 'regular' space. This might be a 'regular' character for which ID substitutes a real minus.
    ... I've never ever seen this one before ...)
    Jul 20, 2012 11:00 AM   in reply to Ken Krugh
    For a font that is internally tagged "Symbol" (which has nothing to do with the old fashioned math font of the same name), InDesign automatically moves all of its characters into the U+F000 range. That is to prevent loosing the correct code for any ol' Dingbat.
    The character code is actually the one for a hyphen, not a minus, but that's okay. The hyphen in the original Symbol font *looks* like a proper minus.
    Snce the imported codes get U+F000 added to them, you could use Find-and-replace to change them to "real" characters. You can search for the literal code
    <F02D>
    and replace with your hyphen, or (better!) an actual minus, whose code is
    <2212>
    ... Geeky as it may sound, yes I *do* know its Unicode from memory ...
    (The ironic backstory here is that the canonical Symbol font, the one *called* "Symbol", imports extremely badly since CS4. Its character set is *not* correctly translated, neither to the U+F000 range nor to actually correct Unicode equivalences. Hence, you get an 'a' instead of an alpha and an '£' instead of a >=. The 'character set' it uses is actually the original worthless Windows Latin-1 "plain" table -- and InDesign attepts to use *that* to translate Symbol symbols, and so its fails miserably. Adobe broke this in, I believe, CS4, and I don't think I've heard it got fixed in later versions. "Broke", because it worked just fine in CS3.
    Irony-upon-irony, the internal files of InDesign still contain a Symbol-font-to-Unicode translation table. It just doesn't get *used*.)
  • Rob Day
    Oct 16, 2007
    Jul 20, 2012 1:16 PM   in reply to Ken Krugh
    The Bitstream Symbol font shows the tilde invisible for any missing basic latin glyph. There are no roman capitals glyphs in bitstream symbol, so ABCDEF etc. all show as invisibles. F02D finds the invisible, but so does the code for any missing latin glyph, i.e., 0047 G:
  • Rob Day
    Oct 16, 2007
    Jul 20, 2012 1:47 PM   in reply to Ken Krugh
    Rob: I'm afraid I'm not getting the point you're making, my ignorance entirely, I'm sure. Are you saying that the "tilde invisble" is what we're seeing above the minus? If so just what does that indicate? Given that the imported plus and equal sign exhibit the same kind of behavoir in the searches shouldn't we be seeing a tilde above those as well?
    The only invisible I can think of that has a charcter showing along with it is an auto hyphen—hidden characters are hidden—things like spaces, line breaks, etc.
    I get the invisible you are showing when I set the cursor to the bitstream symbol font and type anything that's not in the font's basic latin glyph set (ABCD etc.). Glyph panel>Show>Basic Latin.
    I can imitate the invisible over the minus character by reverse tracking or kerning. What does your kerning/tracking show as when you select the text?
    Jul 21, 2012 4:13 AM   in reply to Rob Day
    A small hyphen-minus (FE63) entered from the Mac Character Viewer in the default Minion Pro Regular displays the tilde, but the InDesign glyph panel shows this as Unicode 002D.
    Not sure if this is relevant or just adding to the confusion.
  • Rob Day
    Oct 16, 2007
    Jul 21, 2012 5:12 AM   in reply to ja3754
    I don't get the invisible—I wonder what's different?
    What you're showing looks like an auto hyphen, but you can't keyboard that
    Jul 21, 2012 7:14 AM   in reply to Rob Day
    To Rob Day: The character was inserted using the Character Viewer (part of the Mac OS, not from the InDesign Glyph panel).
    If Substituted Glyphs is checked in Preferences > Composition, the tilded characters are highlighted.
    It is interesting that the InDesign Glyph panel shows the selected character (with the tilde) as 002D, but a Find/Change (Glyph) for 002D won’t find it. If the character is pasted directly into Find/Change (Text) it shows as <FE63> and this will find it.
    So the Find/Change (Glyph) panel won't find substituted glyphs.
    [I know these glyphs are different from the OP's example, but I'm just trying to get my head around how this all works.]
Bookmarked By (1)
