Rocky_XYZZY
"Lng" and "stp" files missing from SSL folder
Jul 20, 2012 3:09 PM
One of our writers' SSL folder is showing differences from the other writers, even though we're presumably starting with the same project files. These differences are causing difficultes when this user attempts to publish.
Among other things, the [projectname].lng and [projectname].stp files are missing from the troublesome environment's SSL folder.
What would be wrong with the project settings or source that would cause these generated files to not appear?
    Jul 21, 2012 1:09 AM   in reply to Rocky_XYZZY
    This looks like a source control issue so I am venturing into the unknown for me as I do not use source control. However, as no one else has come in, any idea is better than none.
    In Snippets on my site there are details of files that should never be checked in or out and the files you mention are not listed. Could it be as simple as the required files are not being accessed?
    @petergrainge
  • RoboColum(n)
    Oct 8, 2004
    Jul 21, 2012 7:36 AM   in reply to Peter Grainge
    It is difficult to say what could be going on here without some more information. Try checking out the project to a brand new location. Do all the required files check out? If they do, you've managed to eliminate any source control issue.
    BTW is there a reason why your output folder is in source control at all? Could you not just publish to a shared drive?
    Jul 21, 2012 7:42 AM   in reply to RoboColum(n)
    Hi Colum
    Just a heads up on the output folder thing. I used to wonder the same thing myself until I finally saw the reasoning.
    There are many tech writers that store only the output folder in source control. The reason is simple. When the application developers create the application, they check out of source control and perform the build. By having only the output files, they are only concerned with the help files that will support their application and need to be included in the build.
    Cheers... Rick
    Helpful and Handy Links
    RoboHelp Wish Form/Bug Reporting Form
    Begin learning RoboHelp HTML 7, 8 or 9 within the day!
    Adobe Certified RoboHelp HTML Training
    SorcerStone Blog
    RoboHelp eBooks
    Jul 22, 2012 12:38 AM   in reply to Rocky_XYZZY
    I have moved this thread to the Source Control forum as that is where the issue lays.
    @petergrainge
    Jul 23, 2012 9:29 AM   in reply to Rocky_XYZZY
    Try with a dummy new project but to the best of my knowledge, if they do not exist on opening a project, they are recreated with default content.
