Need help interpreting how to add this on/off switch to css
Jul 20, 2012 8:43 AM
I have an on/off switch to add to my css
That is what the checkbox looks like now: but I need to add this image:
instead and although I have tried editing the css and changing the class I am not doing something right. Can someone suggest documentation I can go to that I need to read? And by the way - Murray, if you answer this post, please be nice - , I'm sensitive.
Regards, Judith
    Jul 20, 2012 10:43 AM   in reply to JudiFLGator
    Show us your code, please.
    Nancy O.
    Jul 20, 2012 12:42 PM   in reply to JudiFLGator
    A pair of radio buttons would be more appropriate functionality
    Jul 21, 2012 9:47 AM   in reply to JudiFLGator
    Regards, Judith
    Does this imply that my answers are gruff?  I'm a very gentle responder!
    Jul 25, 2012 7:37 AM   in reply to JudiFLGator
    To post your code here, copy it to the clipboard, start a Reply here, and paste into the reply.  You cannot use email to do this.  Alternatively (and even better), upload the file and simply post a link to the uploaded file.
    Aug 22, 2012 2:21 PM   in reply to JudiFLGator
    Here's what I've done in the past. Make sure to change the URL path to your actual image in the CSS...
    Add this into your <head>
    <style type="text/css">
    input[type="checkbox"] {     /* turns off display of the checkbox */
        display:none;
    label {      /* turns labels into a block element and styles it */
        display:block;
        background-image:url(path/to/your-image.jpg);
        background-repeat:no-repeat;
        background-position:0px -27px;
        width:83px;
        height:27px;
    input[type="checkbox"]:checked + label {     /* gives a new style to the label of a checked checkbox */
        background-position:0px 0px;
    Then add this to your body...
        <input type="checkbox" id="check1" value="value1">
        <label for="check1"></label>
        <input type="checkbox" id="check2"  value="value2" >
        <label for="check2"></label>
        <input type="checkbox" id="check3"  value="value3" >
        <label for="check3"></label>
        <input type="checkbox" id="check4"  value="value4" >
        <label for="check4"></label>
    </style>
    Note the checkbox ids and "label for" indentifiers. They need to be the same for each pair.
