PedroHCR
Playback issue
Jul 20, 2012 2:25 PM
Tags: #sequence #playback #windows #cs6 #premier #flickering
I'm having a strange playback issue. When select my second monitor to show the video preview and them play the video both screens start to flash and they stay like this until i stop it. It happens when i move the timeline marker throughout out the timeline too.
My pc:
Intel core i3
8gb ram
Radeon HD 6670
Any ideas to solve that?
    Jul 20, 2012 3:22 PM   in reply to PedroHCR
    More information needed for someone to help... click these links and provided the requested information
    -http://forums.adobe.com/message/4200840
    -http://forums.adobe.com/thread/416679
    Jul 20, 2012 3:56 PM   in reply to PedroHCR
    Might be your underpowered hardware.
    Jul 20, 2012 8:17 PM   in reply to PedroHCR
    >problem was not happening before... before a format my pc... happaning with DV and HDV
    Well, what have you done differently when you reinstalled Windows and all of your software?
    If everything worked until you wiped and reinstalled, it is not Premiere's problem... it is something you did that is not the same as before
    Jul 21, 2012 1:33 AM   in reply to PedroHCR
    PedroHCR,
    You said you're on Windows 7. Have you turned Aero desktop off? With dual monitor setup it can often cause problems with video playback. I recently had serious stuttering that went away right after Aero was disabled.
    So check the Aero setting. That is something that can be easily forgotten after a clean install of everything
    Jul 21, 2012 1:38 AM   in reply to PedroHCR
    If someone find a solution just tell me.
    That is extremely unlikely, due to lack of information from your side.
    Jul 21, 2012 7:48 AM   in reply to PedroHCR
    OK, some hardware is mentioned, such as an underpowered CPU, lacking memory, non-MPE capable video card, and now a single disk.
    You still haven't told which video driver version, what other hard disks you have, their fill rate and connection, the source material, your display setup, what processes are running, what tuning you have performed, etc.
    If you have only one disk, your setup does not meet minimum requirements.
    Jul 21, 2012 8:44 AM   in reply to PedroHCR
    Did you do a complete format and fresh install of Win7 and programs after trying Win8? Did you try using DVI only for both monitors? Have you tuned Win7? How many processes are running?
    Jul 21, 2012 8:48 AM   in reply to PedroHCR
    Pedro,
    Did you try to disable Aero desktop? Don't mind about minimum requirements, "underpowered" CPU and so on, they are not causing your problem as it started only after reinstalling OS.
    Jul 21, 2012 9:03 AM   in reply to Arokki_
    Yeah, like an untrained COPD patient trying to run the New York marathon without shoes but with a 40 lbs backpack.
    Jul 21, 2012 9:05 AM   in reply to Harm Millaard
    Harm,
    Believe it or not, underpowered hardware or running processes in Windows are NOT always the correct reasons for problems, although they are your default answers for everything. You are a 4+ MVP, try a bit harder
    Jul 21, 2012 9:09 AM   in reply to Arokki_
    Hence my questions.
    Aug 21, 2012 6:42 PM   in reply to Arokki_
    Hey thanks for the help Arokki_ I also ran into this probelm on my Windows 7 64bit system and disabling Aero fixed the problem. It could be a AMD driver issue because Im using (2) HD6950's and everywhere I searched with this problem were people also using AMD video cards.
    Aug 21, 2012 10:23 PM   in reply to andrrbnsn
    Hey andrrbnsn! Glad I could help you out! There are tweaks online for getting Aero to function with dual monitor setup but I seem to have lost the link..
