captain_astronaut
Simulate fire light
Jul 21, 2012 2:35 PM
Howdy,
I've got some fire mov files that I'd like to use in my piece, but how can I simulate the light it creates on all the other elements in my composition?
Thanks.
    Jul 21, 2012 3:10 PM   in reply to captain_astronaut
    This depends completely upon your shop. Send us a a scrreen shot and I'll give you an idea.
    Jul 22, 2012 12:01 AM   in reply to captain_astronaut
    The simple solution would be to create a layer with Fractal Noise on top, Mask it out to match the contours more or less, colorize it with Tint or Tritone and use Add Blending mode. Then animate the evolution and offset of the noise and add further adjustments as needed. The hard way would obviously be to duplicate your layers and use elaborate masking and coloring to fake the lighting per edge/ face. If this are 3D layers, of course using a wiggle()expression on a light's intensity property would also work to a degree.
    Mylenium
    Jul 22, 2012 7:26 PM   in reply to captain_astronaut
    You need to separate the dumpster into two parts. Put the foreground part in front of the flames, the background part behind. Then you need to add a copy of the flames that's blurred with probably the screen blend mode to give the appearance of firelight.
    I hope this helps.
    Jul 22, 2012 8:12 PM   in reply to captain_astronaut
    I know I'm probably stating the obvious but the front dumpster layer doesn't appear to turned on.  And, Just to be sure I'm understanding this correctly, you did seperate the back part of the dumpster from the front correct?   Also, I'm not sure what you mean by this...
    If I change the Z axis (forward/backward?) the fire either moves in front of the dumpster or behind no matter what layer it's on.
    The fire should move in front or behind the dumpster if you change the z axis, but it shouldn't matter what layer it's on in 3D space.  The layer order isn't important it only matters where you place the objects.
    Jul 23, 2012 9:18 AM   in reply to captain_astronaut
    Use the pen tool to create a mask.
