ribisph
Link graphic frames and show the same picture on two different spreads
Jul 21, 2012 10:29 AM
Tags: #problem #cs5 #link #indesign #two #spreads
I am creating a brochure in DIN A5 landscape (w x h - 210x148) which has two pages each spread. Now I want to link two graphic frames on two different spreads (starting page 4 continues at page 5) to show the same picture. This picture ist then next to each other after printing.
Please have a look at the pictures (situation and endresult).
Could you please help!
Thank you!
Phil
situation NOW
endresult
    Jul 21, 2012 10:33 AM   in reply to ribisph
    You are going about this the wrong way. Your pages should be set up exactly the way the reader will see them. Imposition should be done when the document is printed.
    By using reader spreads you would place the image once and even if it crosses the spine it will be fine.
    Bob
    Jul 21, 2012 10:53 AM   in reply to ribisph
    Always speak to your printer BEFORE you start any job.
    Bob
    Jul 21, 2012 11:25 AM   in reply to ribisph
    It's not clear to me that you understood that you should be setting this up as a "facing pages" file where each page is half of a spread, not the full-spread per page that you've started with. In order to impose the pages must be independent of each other in the file.
    From the screen shot it looks as if when folded your book will be A5 landscape size, so if that's the case you will want to set up as A5 landscape facing pages. Your layout will have a single page spread for the first and last pages, and the rest will be shown as two-page spreads, just as your reader will see them. Since this appears to be a folded booklet, you also need to keep in mind that the page count should be a multiple of 4 -- two sides of two pages per sheet.
    For handing off to a commercial printer you will probably deliver a PDF, exported as one documetn with individual pages in reading order. If you want to print it yourself, InDesign has a simple built-in imposition module called Print Booklet under the File menu.
    Jul 21, 2012 1:52 PM   in reply to ribisph
    Very good.
    Since you’re a beginner here’s my usual recommendations.
    1. Check out lynda.com. Fantastic value at $25/month for great video courses. This link will get you a one week free trial: http://bit.ly/fcGpiI
    2. Buy Sandee Cohen’s Visual Quick Start Guide. It’s the best beginner book on the market: http://amzn.to/NJZJct
    Bob
