CerviCaus
How to correct perspective in Revolve effect options?
Jul 21, 2012 1:41 PM
Tags: #illustrator #perspective #revolve
Hi!
http://farm9.staticflickr.com/8291/7617314952_04b2d73dec_b.jpg
Here is cylinder made of rectangle using 3d Revolve effect.
I want to change perspective of this cylinder like the red lines show, but it goes a bit to the left. I need exactly to the front. I think this is because perspective based on the center of rectangle (in the green circle) not on the center of cylinder. Is it possible to move the center of rectangle? If not, is any other dicisions how to make what I want?
Thanks.
P.S. Sorry for my english
    Jul 21, 2012 8:53 PM   in reply to CerviCaus
    To rotate forward, adjust change the value I have marked. Leave the other two values at 0.
    Jul 22, 2012 12:53 AM   in reply to CerviCaus
    Did you see the perspective slider?
    Jul 22, 2012 1:23 AM   in reply to CerviCaus
    Yeah, I beleive that has to do with 3 point vs 1 point perspective. (guessing)
    Jul 22, 2012 7:48 AM   in reply to CerviCaus
    I would say it is a poor 3D feature. At the perspective you want the Left and Right Edge of the Offset attribute even at zero is affecting the appearance. They missed to program a Center option.
    As many other things in Illustrator you can use a workaround - revolve just a vertical line instead of rectangle and then increase the Offset in the 3D effect. This will work for the view you want, but the problem is it has no cap and if you want to change the view with this perspective from above or bottom the caps will be missing.
    edit: actually, you can get what you want by using Extrude and Bevel with a circle made with the Ellipse tool. Choose Front view and rotate 90° around the X axes.
