Trouble centering
Jul 21, 2012 2:22 PM
Hope you're well.
As you'll see in the attached screenshot, I've created a graphic in Illustrator that is just type inside a rounded rectangle.
When I try to center the type inside of the rectangle, it doesn't center it. I've measured. Even after I created outlines, it still doesn't center perfectly, it just gets closer.
Is this normal?
    Jul 21, 2012 3:28 PM   in reply to graph22
    graph,
    If you select the live Type with the normal Selection Tool and:
    1) In the Appearance palette/panel flyout tick Add New Stroke,
    2) With the Stroke selected (in the Appearance palette/panel) Effect>Convert to Shape>Rounded Rectangle (just with the default values),
    does the live Type appear centred in that rounded rectangle?
    If not, at least part of the live Type non centring is a matter of how the actual letters are placed within the height of the Em square.
    Jul 22, 2012 2:07 AM   in reply to graph22
    Or select type, go to Effect>Path>Outline Object, then align.
    Edit: Hi, Jacob.
    Jul 22, 2012 2:32 AM   in reply to tromboniator
    Hi Peter,
    Busy or lazy summer? Wet or dry? Cold or hot?
    Jul 22, 2012 2:36 AM   in reply to Jacob Bugge
    Busy, busy, busy; dryish, but now very wet; vying for coldest on record.
    Jul 22, 2012 3:29 AM   in reply to tromboniator
    So all in all, we are better off than our friends in the Lower 48, maybe especially Bert.
    Over here, we have one of the coldest and wettest (and cloudiset) summers ever. It seens to give the opposite issue with the maize/corn, with the lack of sun and heat, most of it being only waist high or less now.
    Steve has said nothing about his (lack of) summer yet.
    Jul 22, 2012 6:10 AM   in reply to Jacob Bugge
    ... because there's been a lack of a lack of summer :-)
    One of the warmest/sunniest on record up here.
    Almost no rain in June and very little in July until yesterday when we had a good soaking.
