In my CS6 Photoshop I can access the filter-gallery but as soon I click on a filter to choose it close the window and I get the error message: the process coulnd't finish. I tried it with several files and and it's always the same message.
I already reset the preferences but this didn't helped a lot. Does anybody know what I can do here?
thanks!
Are the afflicted files 8bit and rgb?
Boilerplate-text:
System Maintenance (repairing permissions, purging PRAM, running cron-scripts, cleaning caches, etc.) might also be beneficial, Onyx has been recommended for such tasks.
http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html
Weeding out bad fonts never seems to be a bad idea, either. (Validate your fonts in Font Book and remove the bad ones.)
http://kb2.adobe.com/cps/843/cpsid_84363.html
If 3rd party plug-ins are installed try disabling them to verify if one of those may be responsible for the problem.
Hello.Could you paste the contents of help>System info... ?
That way, we'll know more about your graphic card setup, your third party plug-ins, etc.
Did it always do that, or did it happen after a change was made on your machine?
Is it the case on every image, on every filter from FG?
Is it set to list all the names in the older categories, or in filter Gallery only?
here is the system info, unfortunately it's in german ;-(
Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
Betriebssystem: Mac OS 10.7.4
Systemarchitektur: Intel CPU-Familie:6, Modell:15, Stepping:6mit MMX, SSE (ganze Zahl), SSE FP, SSE2, SSE3
Physischer Prozessor: 4
Prozessor-Taktfrequenz: 3000 MHz
Eingebauter Speicher: 15360 MB
Freier Speicher: 10116 MB
Für Photoshop verfügbarer Arbeitsspeicher: 14730 MB
Von Photoshop verwendeter Arbeitsspeicher: 70 %
Bildkachelgröße: 1024 KB
Bildcache: 4
Mit OpenGL zeichnen: Aktiviert.
OpenGL-Zeichnungsmodus: Erweitert
OpenGL – normalen Modus zulassen: Wahr.
OpenGL – erweiterten Modus zulassen: Wahr.
OpenGL – alte GPUs zulassen: Nicht erkannt.
OpenGL-Version: 2.1 NVIDIA-7.18.18
OpenCL Version: 1.1 (Apr 9 2012 19:41:45)
Grafikkarten-Hersteller: NVIDIA Corporation
Grafikkarten-Renderer: NVIDIA GeForce 8800 GT OpenGL Engine
Anzeige: 1
Hauptanzeige
Anzeigetiefe:= 32
Anzeigebegrenzungen:= oben: 0, links: 0, unten: 1024, rechts: 1600
Videorenderer-ID: 16918024
Grafikkartenspeicher: 487 MB
Video-Rechteck Strukturgröße: 8192
Seriennummer: 90149113376345365163
Anwendungsordner: Roman Bratschis HD:Applications:Adobe Photoshop CS6:
Der virtuelle Speicher von Photoshop hat asynchronen E/A aktiviert
Arbeitsvolume(s):
Start, 148.2 GB, 14.0 GB frei
Ordner für erforderliche Zusatzmodule: Roman Bratschis HD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
Primärer Zusatzmodul-Ordner: Roman Bratschis HD:Applications:Adobe Photoshop CS6:Plug-ins:
Zusätzlicher Zusatzmodul-Ordner: nicht eingerichtet
Installierte Komponenten
adbeape.framework adbeape 3.3.8.19346 66.1025012
AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.2.29.18602 66.490082
adobe_caps.framework adobe_caps 6.0.29.0 1.276181
AdobeACE.framework AdobeACE 2.19.18.19243 66.492997
AdobeAGM.framework AdobeAGM 4.26.17.19243 66.492997
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.7.101.18636 66.26830
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.7.101.18636 66.26830
AdobeBIB.framework AdobeBIB 1.2.02.19243 66.492997
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 66.492997
AdobeCoolType.framework AdobeCoolType 5.10.31.19243 66.492997
AdobeCrashReporter.framework AdobeCrashReporter 6.0.20120201
AdobeExtendScript.framework AdobeExtendScript 4.2.12.18602 66.490082
AdobeJP2K.framework AdobeJP2K 2.0.0.18562 66.236923
AdobeLinguistic.framework 17206
AdobeMPS.framework AdobeMPS 5.8.0.19463 66.495174
AdobeOwl.framework AdobeOwl 4.0.93 66.496052
AdobePDFL.framework AdobePDFL 10.0.1.18562 66.419471
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 6.0.0.1654
AdobeScCore.framework AdobeScCore 4.2.12.18602 66.490082
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 66.145661 66.145661
AdobeXMPFiles.framework AdobeXMPFiles 66.145661 66.145661
AdobeXMPScript.framework AdobeXMPScript 66.145661 66.145661
ahclient.framework ahclient 1.7.0.56
aif_core.framework AdobeAIF 3.0.00 62.490293
aif_ocl.framework AdobeAIF 3.0.00 62.490293
aif_ogl.framework AdobeAIF 3.0.00 62.490293
AlignmentLib.framework xcode 1.0.0.1
amtlib.framework amtlib 6.0.0.75
boost_date_time.framework boost_date_time 6.0.0.0
boost_signals.framework boost_signals 6.0.0.0
boost_system.framework boost_system 6.0.0.0
boost_threads.framework boost_threads 6.0.0.0
Cg.framework NVIDIA Cg
CIT.framework CIT 2.0.5.19287 145486
data_flow.framework AdobeAIF 3.0.00 62.490293
dvaaudiodevice.framework dvaaudiodevice 6.0.0.0
dvacore.framework dvacore 6.0.0.0
dvamarshal.framework dvamarshal 6.0.0.0
dvamediatypes.framework dvamediatypes 6.0.0.0
dvaplayer.framework dvaplayer 6.0.0.0
dvatransport.framework dvatransport 6.0.0.0
dvaunittesting.framework dvaunittesting 6.0.0.0
dynamiclink.framework dynamiclink 6.0.0.0
FileInfo.framework FileInfo 66.145433 66.145433
filter_graph.framework AdobeAIF 3.0.00 62.490293
hydra_filters.framework AdobeAIF 3.0.00 62.490293
ICUConverter.framework ICUConverter 3.61 "gtlib_3.0" "." "16615"
ICUData.framework ICUData 3.61 "gtlib_3.0" "." "16615"
image_compiler.framework AdobeAIF 3.0.00 62.490293
image_flow.framework AdobeAIF 3.0.00 62.490293
image_runtime.framework AdobeAIF 3.0.00 62.490293
LogSession.framework LogSession 2.1.2.1652
mediacoreif.framework mediacoreif 6.0.0.0
PlugPlug.framework PlugPlug 3.0.0.383
UpdaterNotifications.framework UpdaterNotifications 6.0.0.24 "6.0.0.24"
wrservices.framework
Erforderliche Zusatzmodule:
3D Studio 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“U3D.plugin”"
Adaptive Weitwinkelkorrektur 13.0, Copyright © 2012 Adobe Systems Incorporated - aus der Datei "“Adaptive Wide Angle.plugin”"
ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc. All rights reserved. - aus der Datei "“AdobeADM.bundle”"
Aquarell 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Arithmetisches Mittel 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Asynchrone E/A aktivieren 13.0 20120315.r.428 2012/03/15:21:00:00 © 2004-2012 Adobe Systems Incorporated - aus der Datei "“Enable Async IO.plugin”"
Basrelief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Bereich 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Bildpaket-Filter 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - aus der Datei "“ChannelPort.plugin”"
Blendenflecke 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Buntglas-Mosaik 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Buntstiftschraffur 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Camera Raw 7.1 (354), Copyright © 2012 Adobe Systems Incorporated - aus der Datei "“Camera Raw.plugin”"
Chrom 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Cineon 13.0 20120315.r.428 2012/03/15:21:00:00 ©2002-2012 Adobe Systems Incorporated - aus der Datei "“Cineon.plugin”"
Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“U3D.plugin”"
CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Conté-Stifte 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Diagonal verwischen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“dicom.plugin”"
Differenz-Wolken 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - aus der Datei "“Clouds.plugin”"
Distorsion 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Dunkle Malstriche 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Durchschnitt berechnen 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - aus der Datei "“Average.plugin”"
Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00 ©1997-2012 Adobe Systems Incorporated - aus der Datei "“EazelAcquire.plugin”"
Entropie 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Erfassungsbereich 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - aus der Datei "“MeasurementCore.plugin”"
Extrudieren 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Farbpapier-Collage 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Farbraster 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Fasern 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
FastCore-Routinen 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - aus der Datei "“FastCore.plugin”"
Feuchtes Papier 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Filtergalerie 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Flash 3D 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“U3D.plugin”"
Fluchtpunkt 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“VanishingPoint.plugin”"
Fotokopie 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Fotos freistellen und gerade ausrichten (Filter) 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Fotos freistellen und gerade ausrichten 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - aus der Datei "“CropPhotosAuto.plugin”"
Fresko 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Für Web speichern 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - aus der Datei "“Save for Web.plugin”"
Gekreuzte Malstriche 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Gerissene Kanten 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Glas 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Google Earth 4 KMZ 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“U3D.plugin”"
Grobe Malerei 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Grobes Pastell 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“HDRMergeUI.plugin”"
IFF-Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00 ©2001-2012 Adobe Systems Incorporated - aus der Datei "“JPEG2000.plugin”"
Kacheleffekt 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Kacheln 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Kanten betonen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Kohleumsetzung 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Konturen mit Tinte nachzeichnen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Kreide & Kohle 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Kreuzschraffur 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Kristallisieren 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Kräuseln 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Kunststofffolie 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Kurtosis 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Körnung & Aufhellung 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Körnung 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Leuchtende Konturen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Malgrund 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Malmesser 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Matlab-Vorgang 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - aus der Datei "“ChannelPort.plugin”"
Maximum 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Median 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Mehrprozessorunterstützung 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - aus der Datei "“MultiProcessor Support.plugin”"
Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Minimum 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Mit Struktur versehen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Mit Wasserzeichen versehen KEINE VERSION - aus Datei “DigiSign.plugin”
MMXCore-Routinen 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - aus der Datei "“MMXCore.plugin”"
Neigung 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Neonschein 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
NTSC-Farben 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - aus der Datei "“NTSC Colors.plugin”"
Objektivkorrektur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - aus der Datei "“Lens Correct.plugin”"
Objektivunschärfe 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - aus der Datei "“Lens Blur.plugin”"
OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Ozeanwellen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
PCX 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - aus der Datei "“PCX.plugin”"
Pfade -> Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Photoshop 3D-Modul 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“Photoshop3DEngine.plugin”"
Pixar 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - aus der Datei "“Pixar.plugin”"
PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Polarkoordinaten 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - aus der Datei "“PBM.plugin”"
Prägepapier 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Punktieren 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Punktierstich 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Radialer Weichzeichner 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Radiance 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - aus der Datei "“Radiance.plugin”"
Rasterungseffekt 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Risse 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Schwamm 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Schwingungen 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Selektiver Weichzeichner 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Solarisation 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - aus der Datei "“Solarize.plugin”"
Spritzer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Standardabweichung 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Stempel 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Strichumsetzung 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Strudel 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Stuck 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Summe 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Tontrennung & Kantenbetonung 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
U3D 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“U3D.plugin”"
Unterstützung für Skripten 13.0, Copyright © 2012 Adobe Systems Incorporated - aus der Datei "“ScriptingSupport.plugin”"
Varianz 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“statistics.plugin”"
Verbiegen 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Verflüssigen 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - aus der Datei "“Liquify.plugin”"
Versetzen 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Verwackelte Striche 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Wasserzeichen anzeigen KEINE VERSION - aus Datei “DigiRead.plugin”
Wavefront|OBJ 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - aus der Datei "“U3D.plugin”"
Weiches Licht 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Wellen 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Windeffekt 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - aus der Datei "“WBMP.plugin”"
Wölben 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - aus der Datei "“Standard Multiplugin.plugin”"
Ölfarbe 13.0, Copyright © 2011 Adobe Systems Incorporated - aus der Datei "“Oil Paint.plugin”"
Ölfarbe getupft 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - aus der Datei "“Filter Gallery.plugin”"
Optionale Zusatzmodule und Zusatzmodule von Drittanbietern: KEINE
Nicht geladene Plug-Ins: KEINE
Blitz:
Mini Bridge
Kuler
Installierte TWAIN-Geräte: OHNE
Same kind of problem here with PS CS5 and OSX Lion. Get an annoying "Operation could not be completed" error dialog by activating the Filter Gallery. Reinstalled the app twice, without succes. I'm using an ATI HD 4870 graphics card in my MacPro 1,1.
I guess I finally fixed it by activating the ROOT user, as described here: http://support.apple.com/kb/ht1528 and deleting a file called "com.apple.coreservices.appleid.authentication.plist" as described here: https://discussions.apple.com/thread/3985441?start=0&tstart=0 and reinstalling the wacom driver file: "Wacom Tablet.kext" which is located in System>Library>Extensions. Don't know which one did it, but so far it seems to be solved.. fingers crossed!
