Extension Builder 2.0 and InDesign CS5?
Jul 20, 2012 12:33 AM
I recently tried to create an Adobe Extension that uses host adapters. But after exporting the extension and installing it with the Adobe Extension Manager CS5 I got an error message during startup of InDesign that the host adapter is not a valid plugin. Is it possible that the Extension Manager 2.0 does not support InDesign CS5 with host adapters? Because the plugin without the host adapter works. Or do I need older host adapter plugins? If yes, where can I download them?
Thanks a lot,
Martin
    Jul 20, 2012 2:53 AM   in reply to mallerst
    Hi Martin,
    What is the exact version of InDesign that you are running- is it InDesign CS5 or CS5.1, and on which platform? Can you also post the <files> section of your mxi file?
    Joe
    Aug 6, 2012 7:50 AM   in reply to mallerst
    Hi Martin,
    Sorry for the delay in replying. We are currently looking into the issue. I will keep you posted.
    Joe
    Aug 15, 2012 2:48 AM   in reply to mallerst
    Hi Martin,
    Can you try changing the paths to the host adapters to be absolute paths, and also add the individual folders (csadapters-1.0 and csadapters-2.0) to your project? The host adapters are located under $(ExtensionBuilder_installation)/com.adobe.cside.libsinstaller_xxxx/a rchive/.
    Additionally, modify your mxi entries for InDesign host adapters to target version 7.5 - 7.9 (CS5.5) using csadapters-1.0 and version 8.0-8.9(CS6) using csadapters-2.0. Then download the CS5 ID adapter from the link below and add them to your project to target version 7.0 - 7.4.
    Sorry about the inconvenience. I hope this works out for you.
    Joe
    http://cssdk.host.adobe.com/sdk/2.0/patch/indesign_ha_cs5.zip
    Aug 20, 2012 6:33 AM   in reply to mallerst
    Hi Martin,
    This archive contains the ID host adapters for both CS5 and CS5.5. This should work for your configuration.
    http://cssdk.host.adobe.com/sdk/2.0/patch/id_host_adapter.zip
    Joe
