walken_75
Rtmfp + NetConnection + AIR 2.6 for iOS + wifi.
Feb 27, 2012 1:29 AM
Hello everybody,
I'm currently trying to make an application (a game pad) for iOS (iphone only) with AIR 2.6.
This application have to communicate with a game done in AIR running on a computer thanks to the wifi.
I have read all articles about p2p and rtmfp that I was avaible to find this week end on the internet but nothing help me.
And I don't wana use Cirrus.
To test the concept I have do simple application.
Here is the code of the AIR application that must run on the computer :
import flash.net.NetConnection;
import flash.events.NetStatusEvent;
import flash.net.NetGroup;
import flash.net.GroupSpecifier;
initServer();
var connection:NetConnection;
var deviceGroup:NetGroup;
var gs:GroupSpecifier;
var datas:Object = {};
var numberOfNeighbor:int = 0;
function initServer():void{
          //Initialisation de la connexion
          connection = new NetConnection();
          //Lors de la récéption du NetStatus
          connection.addEventListener(NetStatusEvent.NET_STATUS, onNetStatus);
          //Lancement de la connexion
          connection.connect("rtmfp:");
function onNetStatus(e:NetStatusEvent):void{
          //trace(e.info.code);
          //Si la connexion réussi
          if(e.info.code == "NetConnection.Connect.Success"){
                    trace("Succefully connected to the network.");
                    trace("Trying to set the group.");
                    setGroup();
          //Si la connexion au groupe réussi
          if(e.info.code == "NetGroup.Connect.Success"){
                    trace("Succefully connected to the group.");
          //Si la connexion au groupe ne réussi pas
          if(e.info.code == "NetGroup.Connect.Failed"){
                    trace("Connection to the group failed.");
          //Si la connection au groupe est regetée
          if(e.info.code == "NetGroup.Connect.Rejected"){
                    trace("Connection to the group rejected.");
          //Si un voisin ce connecte
          if(e.info.code == "NetGroup.Neighbor.Connect"){
                    trace("Neighbor connected.");
                    numberOfNeighbor++;
                    trace("There is actually " + numberOfNeighbor + " neighbors connected and me, the server.");
          //Si un voisin ce déconnecte
          if(e.info.code == "NetGroup.Neighbor.Disconnect"){
                    trace("Neighbor disconnected.");
                    numberOfNeighbor--;
          //Si des informations sont reçues
          if(e.info.code == "NetGroup.SendTo.Notify"){
                    datas = e.info.message;
                    trace(datas.data1);
                    trace("bla");
function setGroup():void{
          //Initialisation et paramètrage d'un groupe d'autorisations
          gs = new GroupSpecifier("connectedDevicesGS");
          gs.routingEnabled = true;
          gs.ipMulticastMemberUpdatesEnabled = true;
          //Ip a rejoindre
          gs.addIPMulticastAddress("227.110.8.8:35353");
          gs.multicastEnabled = true;
          //Initialisation du group
          deviceGroup = new NetGroup(connection, gs.groupspecWithAuthorizations());
          deviceGroup.addEventListener(NetStatusEvent.NET_STATUS, onNetStatus);
That is the code for the application application that must run on the iPhone :
import flash.events.MouseEvent;
initClient();
this.addEventListener(MouseEvent.CLICK, sendDatas);
function initClient():void{
                    consoleTxt.text += "Succefully connected to the network. \n";
                    consoleTxt.text += "Trying to set the group. \n";
                    setGroup();
                    consoleTxt.text += "Succefully connected to the group. \n";
                    consoleTxt.text += "Connection to the group failed. \n";
                    consoleTxt.text += "Connection to the group rejected. \n";
                    consoleTxt.text += "Neighbor connected. \n";
                    consoleTxt.text += "Neighbor disconnected. \n";
          //Ip a rejoindre
function sendDatas(e:MouseEvent):void{
          datas.data1 = "data number 1";
          deviceGroup.sendToAllNeighbors(datas);
When I open some instance of the .swf of the iPhone client, all neighbors are detected.
If I compile the AIR application that must be the game, the one who have to run on the computer, all neighbors are detected too.
But if I compile the AIR app for iOS and launch it from my iPhone this neighbor (the iPhone) is not detected and he don't detect instancies of the games / other iPhone app .swf opened on the computer.
Of course the iPhone is connected to the same wifi than the computer.
The strange part is that I have already do that but with an Android App and it was perfectly working.
I wasn't avaible to find a descriptor file for iOs like there is one for Android where you have to say, you know, "ALLOW NETWORK ACCESS" and stuff like that. Is there one ?
Any ideas ?
Thanks for help. ^_^
Cheers,
Walken.
EDIT : I just test the application on an other network and it's working.
On my home wifi this is not working but on the office wifi it's working...
That's realy strange. My home wifi musn't be correcly configured...
One more time, any ideas about this ? ^_^
