I trying to use Adobe Alchemy Compiled C++ code to swc. At the beginning it work pertty good, but when I add more c++ code, Unfortunately, getting it to link ends up producing a link-time error:
Exception in thread "main" java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOfRange(Arrays.java:3209)
at java.lang.String.<init>(String.java:215)
at java.lang.StringBuilder.toString(StringBuilder.java:430)
at macromedia.asc.parser.Scanner.nexttoken(Scanner.java:657)
at macromedia.asc.parser.Parser.getNextToken(Parser.java:673)
at macromedia.asc.parser.Parser.lookahead(Parser.java:631)
at macromedia.asc.parser.Parser.match(Parser.java:434)
at macromedia.asc.parser.Parser.parseAsmDirective(Parser.java:5128)
at macromedia.asc.parser.Parser.parseAsmStatementOrExpr(Parser.java:4949 )
at macromedia.asc.parser.Parser.parseAsmStatement(Parser.java:4927)
at macromedia.asc.parser.Parser.parseStatement(Parser.java:4211)
at macromedia.asc.parser.Parser.parseAnnotatedDirectiveOrStatement(Parse r.java:5645)
at macromedia.asc.parser.Parser.parseDirective(Parser.java:5594)
at macromedia.asc.parser.Parser.parseDirectives(Parser.java:5985)
at macromedia.asc.parser.Parser.parseBlock(Parser.java:4411)
at macromedia.asc.parser.Parser.parseBlock(Parser.java:4397)
at macromedia.asc.parser.Parser.parseFunctionCommon(Parser.java:1631)
at macromedia.asc.parser.Parser.parseFunctionDefinition(Parser.java:6898 )
at macromedia.asc.parser.Parser.parseAnnotatableDirectiveOrPragmaOrInclu de(Parser.java:5916)
at macromedia.asc.parser.Parser.parseAnnotatedDirectiveOrStatement(Parse r.java:5712)
at macromedia.asc.parser.Parser.parseClassDefinition(Parser.java:7542)
at macromedia.asc.parser.Parser.parseAnnotatableDirectiveOrPragmaOrInclu de(Parser.java:5920)
at macromedia.asc.parser.Parser.parsePackageDefinition(Parser.java:8053)
"Java heap space" means Java heap speace not enough, it need to set jave option like "java -Xms128M -Xmx512M -jar..", but I can't find where to set the option in alchemy.
Please help me, Thanks in advance.
Oldmannt
From my answer on StackOverflow:
-g and friends). This causes it to generate a ton of extra code, and often causes it to run out of memory.$jmemmax) in $ALCHEMY_HOME/achacks/gcc.to paleozogt:
Thank you very much!
I have checked, There is no debugging flags in my compile.
I increase the heap-space as you said, but the link error appear all the same. It hit me down... I will try alchemy in windows version,
