snegig
How to move marginalnote out in Structure
Jul 22, 2012 5:23 AM
Hi Scripting guru,
I want my all marginalnote move out in Structure. When marginalnote move in page margin my test from 11p text width. You have any script code. Please accept my sincere apology for take your golden time.
Thanks and have a nice day!
    Jul 22, 2012 11:39 AM   in reply to snegig
    I hope you need place the marginal note has an anchored object? If yes, you can use the below JS code.
    If you post any requirements in the forum please post what you have tried in you end in Java script. Then only some one help to easily. Otherwise is so difficults. Your most of the post always simply shown the snapshots only please place the JS code in your future post.
    var mydoc = app.activeDocument;
    var rootElement = mydoc.xmlElements.item(0);
    var linkElementList = rootElement.evaluateXPathExpression("//marginalnote[@type='mn1']");
    for(var lp=0; lp=linkElementList.length; lp++){
            var myElement = linkElementList[lp];
                    var myTextframe = myElement.placeIntoInlineFrame(["21p9","5p"]);
                   //you have create the object style in you document name is "MN";
                    myTextframe.appliedObjectStyle= mydoc.objectStyles.item("MN");
    alert("Proces Completed");
    thx
    csm_phil
    Jul 23, 2012 2:45 AM   in reply to snegig
    Do you want to untag the "marginalnote" element from structure pane or move to the root element?
    Requirement not clear...
    Jul 23, 2012 3:39 AM   in reply to snegig
    Hi Sneig,
    I have modifed the above JS code. Please try this.
    If your document have only one marginal note then the script will through the error. So I have changed the reverse loop thats all.
    for(var lp=linkElementList.length-1; lp>=0; lp--){
                   //you have create the object style in you active document the object style name is "MN";
    thx
    csm_phil
