Hi everyone,
This is from an old post from 2009 originally in the InDesign forum, http://forums.adobe.com/thread/451768?start=0&tstart=0
This JS that Harbs wrote works great for me in IDCS4.
try{SetPrefs()}
catch(e){}
function SetPrefs(){
var e;
var doc=app.documents[0];
doc.viewPreferences.properties= {
horizontalMeasurementUnits : MeasurementUnits.points,
verticalMeasurementUnits : MeasurementUnits.points,
rulerOrigin : RulerOrigin.PAGE_ORIGIN,
cursorKeyIncrement : 1
doc.textPreferences.properties = {
superscriptPosition : 33.3,
superscriptSize : 65,
subscriptPosition : 33.3,
subscriptSize : 65,
smallCap : 75,
baselineShiftKeyIncrement : 0.1,
leadingKeyIncrement : 0.1
var styleProps = {
composer : "Adobe Single-line Composer",
minimumWordSpacing : 85,
desiredWordSpacing : 100,
maximumWordSpacing : 133,
minimumLetterSpacing : 0.0,
desiredLetterSpacing : 0.0,
maximumLetterSpacing : 0.0,
hyphenateAfterFirst : 2,
hyphenateBeforeLast : 3,
hyphenateLadderLimit : 2,
hyphenateCapitalizedWords : true
try{var styles=doc.allParagraphStyles;}
catch(e){var styles = doc.paragraphStyles}
for(var i=1;i<styles.length;i++){
styles[i].properties=styleProps;
Is there a way to make this script toggle between the custom settings here, then setting them back to the original document settings?
Many thanks,
gr
Thank you Harbs. Sorry I mean I just want to toggle between two sets of values (the templates the designers use always have the same preferences)
e.g.
MeasurementUnits between points and millimeters
leadingKeyIncrement between 5 and 1
etc.
Right now I just use your script twice; one with my preferred values and after I'm done and ready to pass the file back to designers, I click on the other one which restores the values set on the template.
patched together, but works for me : )
var myDoc = app.activeDocument;
var myDocVerticalUnits = myDoc.viewPreferences.verticalMeasurementUnits;
var myDocHorizontalUnits = myDoc.viewPreferences.horizontalMeasurementUnits;
var myNewUnits = myDoc.viewPreferences;
switch (myDocVerticalUnits)
case 2053991795:
myNewUnits.verticalMeasurementUnits = MeasurementUnits.picas;
break;
case 2054188905:
myNewUnits.verticalMeasurementUnits = MeasurementUnits.millimeters;
break;
default: //apply for anything else millimeters as ruler units.
break;
switch (myDocHorizontalUnits)
case 2053991795:
myNewUnits.horizontalMeasurementUnits = MeasurementUnits.picas;
break;
case 2054188905:
myNewUnits.horizontalMeasurementUnits = MeasurementUnits.millimeters;
break;
break;
if (myDoc.viewPreferences.horizontalMeasurementUnits == MeasurementUnits.millimeters &&
myDoc.viewPreferences.verticalMeasurementUnits == MeasurementUnits.millimeters)
{myDoc.textPreferences.properties = {
leadingKeyIncrement : 0.1,
kerningKeyIncrement : 1
else {myDoc.textPreferences.properties = {
baselineShiftKeyIncrement : 0.5,
leadingKeyIncrement : 0.5,
kerningKeyIncrement : 5
