SeaMonkey And Windows 7 64-Bit
Jul 19, 2012 1:22 PM
Friends and neighbors, my previous discussion thread, "Slow Browsing Since Update," went unanswered.  Anyway, if I am going to view flash in SeaMonkey, having quit finding an alternative program that works, then I will have to get Flash Player to work.  However, having downloaded and installed it, it does not appear on SeaMonkey's list of Addons.  Why?
    Jul 19, 2012 9:21 PM   in reply to troothteller
    I do not know SeaMonkey; how does it look for add-ons - same way as Firefox?
    Jul 19, 2012 9:37 PM   in reply to troothteller
    P.S. what files do you have in
    • C:\WINDOWS\system32\Macromed\Flash ?
    • C:\WINDOWS\syswow64\Macromed\Flash ?
    Jul 20, 2012 8:15 PM   in reply to troothteller
    That looks all perfectly correct.
    I will try to install Seamonkey during this weekend and see if I can find out anything.
    P.S. do you have Firefox installed, and does Flash Player work correctly on FX?
    Jul 21, 2012 8:15 PM   in reply to troothteller
    I have installed Seamonkey, and the Shockwave Flash plugin shows up normally.  It also works normally.
    I have observed the startup of Seamonkey using Process Monitor, and it uses the same technique to load the Flash Plugin as Firefox, via HKLM\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayer\Path
    Questions:
    • do you see the Shockwave Flash plugin if you go to about:plugins ?
    • do you have HKLM\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayer\Path in the registry, and where does it point to?
    Jul 22, 2012 9:11 PM   in reply to troothteller
    Sorry for that; HKLM is short for HKEY_LOCAL_MACHINE.
    forthteller wrote:
    Thank you for getting back to me on this hot, busy weekend.
    We were having a rather cool weekend; 19°C - the coolest summer in living memory!
    Jul 23, 2012 12:02 AM   in reply to troothteller
    forthteller wrote:
    The Path shows C:\windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_265,dll
    Is that comma before the dll extension a typo, or is it indeed like that in the registry?
    It should of course be a period (dot); otherwise it would explain why Seamonkey is unable to load it.
    Jul 23, 2012 1:44 AM   in reply to troothteller
    What you should do next is the following...
    Download Process Monitor and unzip it, then run it.
    At the start it will present you with a Filter panel.  Under 'Display entries matching these' enter Process name is seamonkey, and click the Add button.
    Click OK, then start and stop Seamonkey.
    Now use the Find function (Ctrl+F) to look for NPSWF; maybe you will be able to find why SM does not load the Shockwave Flash plugin.
    If it doesn't find anything NPSWF, then look for MozillaPlugins.
    You can also save the entire ProcMon output and post it here, or send it to me via email; I will send you a PM with my email address.
    Jul 23, 2012 6:41 PM   in reply to troothteller
    This forum editor has a knack jumping around when trying to insert a hyperlink...
    Here is the correct link:
    http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
    Jul 23, 2012 7:26 PM   in reply to troothteller
    If Flash Player is working, and keeps working, then there is no need to run Process Monitor.
