CTSRick
Unicode Khmer font display problems in FrameMaker 10?
Mar 22, 2012 6:50 PM
Tags: #framemaker_10; #khmer; #cambodian.
How do I get Khmer OS or any unicode Khmer font to display properly in FrameMaker 10?
I am working with cambodian files in FrameMaker 10.
This is what it looks like in Word (this is how it should look)
This is how the same texk looks in FrameMaker 10...
The font is NiDA Chenla and I was able to fix this is ID CS5.5 by turning on the World-Composer.
Is there something similar in FrameMaker 10.
    Jul 23, 2012 6:21 AM   in reply to CTSRick
    Have you actually contacted Adobe Support? The forums are a user-to-user concern – some staff hang around, but it’s mostly just users. If no-one took a stab at your post, then it’s likely that no-one knows the solution for your issue. Does it look ok in any output you produce (PDF, WebHelp, etc.) or is the font munged up there too?
    Jul 23, 2012 9:10 AM   in reply to Jeff_Coatsworth
    Hi CTSRisk,
    Probably spread and stretch option in Character designer might get if fixed for as i dont know the language,i am assuming the language is ok and the only problem is the spacing between them.
    If yes,kindly goto character designer and change the spacing between them.
    I apologize for the late response,however sometimes its not possible to answer on the forums quickly for us.
    Let me know in case i understood the question wrong.
    Harpreet.
