Question
Jul 23, 2012 12:22 PM
Tags: #tags #template #container #wrapper
I have a really quick question.  If I plan to use two different templates to create one website, can I create one template with a wrapper tag and the other with a container tag?  The reason being that the dimensions for both will be different.  Thanks ahead of time.
    Jul 23, 2012 12:31 PM   in reply to Ivy54
    A wrapper tag and a container tag are the same thing, you know?  Your question is a bit odd as a result.
    However you can certainly have more than one template in a site (although it's not optimal), and each template can have a different layout design.
    Jul 23, 2012 12:37 PM   in reply to Ivy54
    Not really.  In your mind, what is the difference between a 'wrapper' tag and a 'container' tag?
    If the question you are asking is "Can I create two templates for a site, one of which specifies a page width of 800px and the other of which specifies a page width of 600px?" then the answer is "Certainly you can".
    Jul 23, 2012 12:43 PM   in reply to Ivy54
    I don't like using multiple templates either.  A better approach might be to create two CSS Layout classes:
    #wrapper {margin: 0 auto; border: 1px solid green}
    .layout1 {width: 900px}
    .layout2 {width:500px}
    HTML:
    <div id="wrapper" class="layout1">
    This is layout 1
    </div>
    <div id="wrapper" class="layout2">
    This is layout 2
    </div>
    Does this make more sense?
    Nancy O.
    Jul 23, 2012 12:48 PM   in reply to Nancy O.
    I should add, that you can accomplish this with only 1 Template by making the class attribute editable in your Template and Child pages.  See F1 (help) making an editable attribute in Templates.
    Nancy O.
    Jul 23, 2012 12:49 PM   in reply to Ivy54
    So let me try to clarify:
    A container tag and a wrapper tag are both HTML elements that can contain other HTML elements.  For example, a div, or a table, or a paragraph, or a span, or a list element are all containers and at the same time can all be wrappers - it's like TO-MAY-TO vs TO-MAH-TO.  An image is NOT a container or a wrapper.  Neither is a break, or a horizontal rule.  Your continued use of these two identical ways of referring to HTML tags is confusing you.
    Now, you say "each template has 2 different dimensions..." and I say "HUH?".  Let's cut to the chase - show us an example of what you are wanting to use for the two templates (the code please).
