I have a really quick question. If I plan to use two different templates to create one website, can I create one template with a wrapper tag and the other with a container tag? The reason being that the dimensions for both will be different. Thanks ahead of time.
Right, the wrapper tag will be used to create one template (ex. dimensions will be 800 x 933) and the container tag will be used to create another template (ex. dimensions 600 x 933). The header and the menu bar will be the same, it's just an adjustment in the content area. Does that make sense? Do you have another suggestion?
Not really. In your mind, what is the difference between a 'wrapper' tag and a 'container' tag?
If the question you are asking is "Can I create two templates for a site, one of which specifies a page width of 800px and the other of which specifies a page width of 600px?" then the answer is "Certainly you can".
I don't like using multiple templates either. A better approach might be to create two CSS Layout classes:
#wrapper {margin: 0 auto; border: 1px solid green}
.layout1 {width: 900px}
.layout2 {width:500px}
HTML:
<div id="wrapper" class="layout1">
This is layout 1
</div>
<div id="wrapper" class="layout2">
This is layout 2
</div>
Does this make more sense?
Nancy O.
There is no difference between a wrapper and container tag.
Sorry, let me rephrase my question. If I use a container tag for both templates and each template has 2 different dimensions won't dreamweaver get confused? That is why I thought using a wrapper tag for one template and container tag for the other template would be less confusing.
So let me try to clarify:
A container tag and a wrapper tag are both HTML elements that can contain other HTML elements. For example, a div, or a table, or a paragraph, or a span, or a list element are all containers and at the same time can all be wrappers - it's like TO-MAY-TO vs TO-MAH-TO. An image is NOT a container or a wrapper. Neither is a break, or a horizontal rule. Your continued use of these two identical ways of referring to HTML tags is confusing you.
Now, you say "each template has 2 different dimensions..." and I say "HUH?". Let's cut to the chase - show us an example of what you are wanting to use for the two templates (the code please).
