I suspect I"m missing a button somewhere that does this, but...
I want to remove a catalog from the list of catalogs that shows up when starting Lightroom. I don't want to delete it or mess with it in any way 'cause it's a backup. SOMEHOW (just let it lay there - you can chuckle internally) I managed to grab the backup catalog one time and now its in the list, and every so often if I'm not paying attention I open the wrong one...
So, how do I make that entry in my catalog list go away without actually deleting anything or doing anything to the catalog?
The LR internal catalog-recency list is stored in the LR preferences file. On my 64-bit Windows 7 computer the LR preferences file is here:
C:\Users\yourusername\AppData\Roaming\Adobe\Lightroom\Preferences\ Lightroom 4 Preferences.agprefs
where AppData is a hidden folder so you may have to type it into the Explorer address bar if you don’t have Show Hidden and System Files and Folders enabled in Folder Options in Windows Explorer.
The library names can be more than once so I’d suggest searching for a unique part of the path and making sure you delete all instances of it. Make a backup of your preferences file before hacking away.
Renaming the catalog slightly is probably enough to get LR to balk and let you remove it; however, I think the name may go into the Missing list, instead.
You could also just delete (or rename with a different extension) the preferences file and let LR rebuild it, after clicking around to take an inventory of what your current settings are.
