How do I avoid the dreaded "jaggies" when saving for the Web?
Jul 22, 2012 7:37 PM
Tags: #illustrator #dreamweaver #png #vector #jaggies
I created vector art in Illustrator, then saved the file as an .ai file.
Afterward, I chose "Save for Web," and exported the file as a .png file.
I placed the .png file at 100 percent into a Dreamweaver file.
The result is a file with jagged edges. How do I save the file to preserve the smooth vector look of the original file?
    Jul 22, 2012 9:23 PM   in reply to pk4ut
    In the save or the web dialog you will notice in the image size area it gives you an opttimzing Options I believe the default is none change it to either Art Optimize or Type Optimize depending on what you are saving.
    Jul 23, 2012 10:55 AM   in reply to pk4ut
    pk4ut,
    What happens if you use Art Optimize?
    In older versions you just ticked the Anti-Alias button hidden away in the Image Size window. I believe that has been split into art and type, and it for your case, art would seem more relevant.
    Jul 23, 2012 3:17 PM   in reply to pk4ut
    The result is a file with jagged edges. ...
    Was the preview in Save for Web jagged too? Are you checking the result in Dreamweaver by opening the created web page in a browser?
