i have problems, when converting from raw to jpegs sometimes my computer crashes completely, a complete stop!!!!
other times it comes up with problem and needs to shut down listing
AppName: lightroom.exe AppVer: 3.6.0.10 ModName: msvcr100.dll
ModVer: 10.0.30319.415 Offset: 00010b90
AppName: lightroom.exe AppVer: 3.6.0.10 ModName: cameraraw.dll
ModVer: 3.6.0.10 Offset: 001fc314
i do NOT have any phones conected to my pc so that is NOT an issue why is this happening?
Lightroom version: 3.6 [795620]
Operating system: Microsoft Windows XP Professional Service Pack 3 (Build 2600)
Version: 5.1 [2600]
Application architecture: x86
System architecture: x86
Physical processor count: 2
Processor speed: 3.1 GHz
Built-in memory: 3326.4 MB
Real memory available to Lightroom: 716.8 MB
Real memory used by Lightroom: 258.9 MB (36.1%)
Virtual memory used by Lightroom: 256.1 MB
Memory cache size: 61.6 MB
System DPI setting: 96 DPI
Displays: 1) 1920x1080
I'd verify the type and make sure that you are using the latest driver available for this card from here http://support.amd.com/us/Pages/AMDSupportHub.aspx.
I've only had LR crashing while rendering previews (similar to exporting) twice. Once was caused by a faulty power supply, and the other was caused by me overclocking the computer too much. But I use Win7x64. XP is now over 10yrs old (a lifetime in computer terms) and was much more prone to crashing than Win7. So my first suggestion is to update to Win7.
Bob Frost
adobe why can,t you give me a definitive answer to this problem?
Because the crash appears to be occurring as a result of something wrong on your system. If you have all of your system updates installed, then likely the problem is that some of them have become corrupted or didn't install correctly. With the information available, my only suggestion currently is to uninstall and reinstall all of the Microsoft Visual C++ Redistributable packages.
Try running CCleaner to remove unnecessary temp files. (filehippo,com) Also check config file (msconfig) using filehippo. Remove unneccessary pointers in ms config loading in. See what these suggestions do.
Remove unnecessary files from your hard drive.
Also, remove swap file . it will rebuild itself on next boot.
Do one chancge at a time.
point the swap file to a empty drive if available.
Make sure the raw files that you are using are not damaged.
Just some suggestion.
Le me know if any works
