JesRoberts
Hyphenated Word
Jul 24, 2012 1:21 AM
Hi Friends,
How to get the Before and After hyphenation words in indesign scripting.
Example:AAAA-BBBBj(Automaticaly hyphenated)
How to get AAA & BBBB and save in separate variables.
Please give idea.
    Jul 24, 2012 1:32 AM   in reply to JesRoberts
    @JesRoberts – you could test for the "lines.length" property of the word. If there is more than one line, the word is split. But that does not give you the parts (could be more than two). So you have to test for the lines index of every single character of the word.
    Uwe
    Jul 24, 2012 1:47 AM   in reply to JesRoberts
    uh..
    i did something like this a while ago, but i can't find the code.
    the problem is that the automated hypen does not apear in the text variable.
    so.. (assuming that AAAABBBB is stored in myVariable)
    myVariable.lines[0] will get the line, ending with the first part of the word,and
    myVariable.lines[1].. you get the ideea.
    unfortunatly using
    myVariable.lines[0].words[-1] will give you the entire word (AAAABBBB) so the trick i used was to insert a space at the end of the line like:
    myVariable.lines[0].insertionPoints[-1].contents=" "; then get the first and last part of the word using
    .lines[0].words[-1] and .lines[1].words[0] then remove the added space (.lines[0].characters[-1].remove())
    ps. it's just a guide to get you started, in the actual code you will have to be a bit more careful.
    Jul 24, 2012 2:07 AM   in reply to JesRoberts
    Hi Friend,
    Use the below code to select the first part and second part seperately.
    Javascript Code
    var myTxt = app.selection[0];
    var myChar1 = app.selection[0].lines[0].characters[-1];
    var myChar2 = app.selection[0].lines[1].characters[0];
    myTxt.characters[0].select();
    myChar1.select(1633969202); // SelectionOptions.ADDTO
    alert("First part selected");
    myChar2.select();
    myTxt.characters[-1].select(1633969202);
    alert("Second part selected");
    Ramkumar .P
Bookmarked By (1)
