Help with using the pen tool
Jul 24, 2012 6:16 AM
Tags: #issue #overlap #path #tool #stroke #cs6 #jumping #pen #pen_tool #typing #adding_text
I have a few different problems with the pen tool.
1. When using the pen tool I keep finding that the shape I'm doing is slightly overlapping where I've already gone with the pen tool.
If I try and go over that area again the path I've just drawn then jumps and ruins the shape I was creating.
How can I stop this from happening?
2. Also is there a limit to the amount of paths you can create and add text to? I created two paths and typed on them fine but when I added a third path it refused to type. The cursor didn't change to show I could type and if I did click on the path line and try to type jumped to my other path and typed there. All paths were on different layers and none were overlapping, but it is 3 circles inside each other that get smaller if this makes a difference.
How can I type on the third path?
3. When I have done a path and clicked stroke it is only a thin line. How can I make this line thicker?
Thanks.
    Jul 24, 2012 6:37 AM   in reply to timeofthemoon
    Could you please post a screenshot with the pertinent Panels visible?
    Could it be you have set the Preferences > General > Snap Vector Tools …?
    What is the selected Tool and does it have Shape Dynamics set in the Brush Panel?
    Jul 24, 2012 7:42 AM   in reply to timeofthemoon
    The next one I was creating a car speedometer so it has lines on the outside, dots inside of that and then, where I've done the blue circle, would be the third path where I then write the numbers in. But I can never write on that third path.
    Could you post a screenshot with the Layers and Paths Panels visible?
    Is the active Path the Work Path or a Vector Mask?
    Jul 24, 2012 11:06 AM   in reply to timeofthemoon
    Ps seems easily confused by the presence of text nearby the path to which you want to add text. Hide the first two text layers then you'll be able to create the third one.
    By the way, don't you find it tricky to get the result you want when you transform the path only of a text-on-path layer; the text doesn't update until you confirm the transform. Yet again, Ps is surprisingly non-interactive for a graphics application in 2012, especially one so expensive!
    Jul 24, 2012 1:20 PM   in reply to timeofthemoon
    timeofthemoon wrote:
    I tried hiding the layers below, it didn't help, it just refused to type. I tried locking the other layers and it wouldn't type. I even tried deleting the other paths and creating the third and it still jumped down to the other layers. I've tried creating a new document and starting over but it's still the same...
    Hmm... hiding interfering text layers lets me proceed with creating new layers of text on a path, so I don't know what to suggest.
    While I think about it, how do you get the text to be on the inside of a path instead of the outside? I know I've done it before but I can't remember how.
    Quick tut at http://www.photoshopessentials.com/basics/type-on-a-path/
    Jul 24, 2012 2:10 PM   in reply to timeofthemoon
    Do you know anything about the other problem I asked about at the start with the paths overlapping?
    No, I don't know what's happening there.
    Jul 25, 2012 12:22 AM   in reply to timeofthemoon
    Pretending the lines go elsewhere, say I've drawn a path with the pen tool, gone round the bottom box and that then goes round the two lines going down. So if I go down the one on the left side it hits the previous path I did, but to go up the line on the right side I'd need to go across there. But if I make a point where the two lines meet to do this it then throws the line off elsewhere.
    I don’t understand what you mean.
    Could you post step by step screenshots?
    Jul 25, 2012 3:35 AM   in reply to timeofthemoon
    Could you post a screenshot of the whole path?
    Paths don't have to be closed and you can start new paths (subpaths) as in the example below:
    (click on the screenshots for larger views)
    unclosed paths:
    the paths selected:
    the paths stroked with the bush tool:
    Jul 25, 2012 6:09 AM   in reply to timeofthemoon
    Paths and layers are two different things and you don't need to create a layer to draw paths.
    (well there are shape layers and vector masks which use paths)
    maybe some of these tutorials will help: (none are specific to cs6, but the basics are the same)
    http://www.elated.com/articles/photoshop-paths-explained/
    http://www.adobepress.com/articles/article.asp?p=732109
    http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-73a0a.html
    Jul 26, 2012 5:38 PM   in reply to timeofthemoon
    Okay, I just started learning Photoshop about three weeks ago… I'm a quick learner.
    Maybe some of the older pros can correct me on this.
    When you're creating the new path for line 5…the path going up
    Add an anchor point on the bottom line/path/stroke before you continue creating your path going up…
    Aug 11, 2012 2:14 AM   in reply to WidmarkRob
    I don't know if I should say this or not, but I would seriously consider learning Illustrator to do your vector work in, especially "advanced or complicated" vectors. You can import them later to Photoshop to add "photo realism and effects".
    This approach just seems so masochistic to me... sorry. Even IF you can do some pretty amazing things within Photoshop and using vectors, the question remains: do you want to, or should you not explore another program within the Creative Suite to do it better and easier?
    Just a humble opinion.
    Aug 11, 2012 2:23 AM   in reply to DocPixel-BMW
    Illustrator certainly offers superior path manipulation functionalities … and yet in some regards I consider it inferior to Photoshop’s path manipulation.
    Two issue come to mind: the path closing behaviour and the free/perspectival transformation of paths.
