Hello,
I am having an issue creating a simple graphic with no effects added. I have 2 layers one is a logo the other is shapes. Using the Ellipse tool I'm creating up to 73 circles and when I want to change the size or color of the circle after effects slows down completly and shows the "color wheel spinning" then still does not change the color. When this is happening I have the red wireframes through my image with a message saying adaptive resolution.
I do not know why this is happening and how do I fix this?
Here are my specs and I will add a screen capture:
MacBookPro Retina, 2012
Processor 2.3 GHz Intel Core i7
Memory 8 GB 1600 MHz DDR3
Graphics NVIDIA GeForce GT 650M 1024 MB
Software Mac OS X Lion 10.7.4 (11E2620)
After effects:
Trial version 11.0.1.12
Thank You for your help ![]()
Here is a screen grab of the issue:
http://www.youtube.com/watch?v=49Q10RAxsS8&feature=player_embedded
Also when viewing my Activity Monitor After Effects is using up to 75% CPU
I've got a MBPro Retina and I'll be happy to take a look at your project.
Did you run the terminal commands necessary to add the Cuda Drivers for the MBPro??? If not, you can find instructions here. I'm actually quite happy with my setup.
Set to final quality is found in the Fast Previews section of the Comp Panel.
Thank You Mylenium and Rick..I just ran the terminal commands to add Cuda Drivers and selected Final Quality in my comp settings and it works better than it did but it is still a little slow?!?![]()
