Gaussian Blur Filling Object?
Jul 23, 2012 7:49 PM
Tags: #help #tutorial #clipping_mask #gaussian_blur #photoshop_cs6
Hello:        My Level: Newbie  OS: Windows 7 64bit  Photoshop CS6
I'm at it again. An other tutorial with missing info etc.
Actually, I think it may be a Ps issue.
This is what I'm doing...
Create a shape with the Rounded Rectangle > I apply a Gradient & Bevel
New Layer > Fill with White > Ctrl + Alt + G (clipping mask) > change Layer Blend to Multiply > Opactity to 35% > Filter > Noise > Add Noise
New Layer > Ctrl + Alt + G > Ctrl + Click on the Rounded Rectangle Shape to create a Selection
From there I am suppose to add a Stroke by right clicking on the object but that doesn't work. The only menu that pops up is a list of my layers
So, rather I select the Rounded Rectangle layer and then click Effects and select Stroke and then set the values for the stroke
Next I am suppose to add a blur.
Blur > Gaussian Blur but the Stroke ends up filling the entire object. No, I didn't set the Blur to like 1,000 it's only set to 5.9
I tried this on an other computer and the same thing happens. I called Adobe but they were unable to help me even get as far as the Stroke
Any ideas why the entire object ends up filled?
This is driving me totally Insane.
    Jul 23, 2012 7:58 PM   in reply to Kar209
    Are you applying the blur to the shape layer?
    When you try the gaussian blur filter do you get a message about the Shape layer needing to be rasterized before applying the filter?
    It sounds like maybe your supposed to stroke the selection on the blank layer (Edit>Stroke>Inside) and then run the gaussian blur filter just on the stroke.
    The menus that appear when right clicking can be different depending on what tool you have selected in the toolbox or where in the photoshop window you right click.
    Could you give a link to the turtorial?
    Jul 24, 2012 5:49 AM   in reply to Kar209
    Do you know what tool I should have selected in order to have the stroke appear in the menu when I right click? That did occur to me but the ones I tried didn't seem to make a difference.
    You need any of the selection tools (e.g. Rectangular Marquee or Lasso) to be active and a pixel layer to be targeted for that right-click menu with "Stroke..." to appear. "Stroke..." is also available in the Edit menu, regardless of active tool, when there is a selection and targeted pixel layer.
    Yes. When I try the gaussian blur it does say that the shape needs to be rasterized beforehand. Which I thought was odd/wrong.
    The blurs, like all Ps filters, need pixels on which to operate. You could make a Smart Object of a shape then attach a blur filter to it, with the added advantage of the blur being nondestructive and adjustable.
    When I did a live chat with Adobe today (for hours ~ of my life I'll never get back lol) the person that helped me told me to skip doing it the way the tut instructed and to just place the Stroke on the shape layer with the blending option.
    Photoshop's Layer Style Stroke has room for improvement. One problem is that it produces poor results with hard brush-painted regions and absolutely terrible results with soft edges such as soft brush-painted or blurred regions.
    Jul 24, 2012 11:34 AM   in reply to Kar209
    Kar209 wrote:
    conroy ... thank you for your reply
    When I go to Edit > Stroke the Stroke is not available/it is greyed out. And I have made certain that there's a Selection by Ctrl + Click on the thumbnail of the Rounded Rectangle/iPad layer
    Am I suppose to still have the blank layer selected/blue when I Ctrl + Click the iPad layer? Could that be why the Stroke is Never available?
    Yes, you need a regular pixel Layer to be targeted for Edit > Stroke to be available.
    As of now the Only way I can get a Stroke is via the Blending option.
    Do you know why, when I apply the Gaussian Blur, the entire shape is Filled with a color?
    You have put a Layer Style Stroke on the layer, and like I said earlier, LSS gives terrible results with blurred regions.
    When I went through the steps on my other computer it Filled with Light Blue rather than Black. ?????
    I guess you had blue specified for the LSS colour on one computer and black on the other computer.
    Okay, well going to give it an other go.
    Thank you again!
    Good luck, and you're welcome!
    Jul 24, 2012 12:48 PM   in reply to Kar209
    Ensure the bottom Shape Layer, the one that clips the layer with the stroke, has a fill.
    If that's not the solution, are there any layers above the layer with the stroke that isn't visible in the doc window?
