Trial versions of Adobe Creative Suite, Photoshop Elements, and Adobe Premiere Elements are downloaded using the Adobe Download Assistant — a small application that is meant to improve download reliability and avoid issues that commonly occur during large downloads, such as frequent disconnects.
What do we mean by "large downloads"? Photoshop CS5 and Photoshop Elements, for example, are each over 1.1 GB. The approximate download times for files this size are:
• On a cable connection (3 mbps): 50 minutes.
• On a DSL connection (1.5 mbps): 1 hrs. 39 minutes.
The Adobe Download Assistant helps most people manage the download of these large files, for example by enabling pause/resume of the downloads, and checking to ensure the complete file(s) are downloaded before actual installation begins.
While we strongly recommend you first attempt to download trial versions using the Adobe Download Assistant, we also realize that some people just prefer to manage their own downloads directly, using a web browser. For those of you who do, please follow the instructions carefully here.
Update 5/5/13: Please utilize the Photoshop Elements page at http://www.adobe.com/cfusion/tdrc/index.cfm?product=photoshop_elements &loc=us to set the trial cookie to allow the links offered at http://prodesigntools.com/adobe-cs6-direct-download-links.html to function successfully.
Jamrak7 it appears other users have posted regarding this as well. I would recommend you try repeating the instructions given on the site again. Perhaps try an alternate web browser this time? It is also possible there could be some time in the next days when the trials maybe unavailable as we prepare to make Creative Suite 6 and Creative Cloud available.
Hello,
Let me provide you a work around inorder to download the product.
Try to open the trial download link of the Light-room 4.
https://www.adobe.com/cfusion/tdrc/index.cfm?product=photoshop_lightro om&promoid=DJDUX
Keeping this page open, try to download your product.
-Yuvraj.
I read all the posts and replies by Adobe and none of them helped. I was experiencing the non-responsiveness from the Download Assistant after having successfully downloaded CS6 trial on my iMac but having the problem on my Macbook Pro.
Using the direct link to the file is working like it should and was the SOLUTION. For CS6 the direct link is: http://prodesigntools.com/adobe-cs6-direct-download-links.html
Save hours if not days of frustration and get the direct link to the file.
The download assistant is just aweful and Adobe should get rid of it now.
c1natra33 as previously mentioned in message #2 if you are receiving the access denied error it is due to not fully completing the instructions. You need to make sure and log in and download a trial through the typical method before you can utilize the direct links. If you have further questions I would recommend reviewing the comments at Prodesigntools.com.
c1natra33, -
Let us make it simple for you, first sign in to Adobe.com, go to any product and click on 'Try', when you are done with that, and the download starts, then cancel it.
paste the Direct link and the download will start on its own.
For the next person, these are the all-important instructions that Jeff refers to:
if you are having this issue on a mac, here is your solution
https://discussions.apple.com/thread/3789130?start=0&tstart=0
just skip pass the verification window you get when opening the disk image and you will not run into any problems.
I was trying everything I could think of on my end to download the InDesign trial from this link:
http://prodesigntools.com/trials2/AdobeProducts/IDSN/8/win32/InDesign_ 8_LS16.exe
I must have tried it a hundred times using every browser, download manager, login, logout, whatever. At one point the server sent me a 1.2 MB file that was corrupt, but on all other attempts it just errored out. The current response entity is:
Access Denied
You don't have permission to access "http://trials2.adobe.com/AdobeProducts/IDSN/8/win32/InDesign_8_LS16.ex e?" on this server.
Reference #18.6daeacd.1343153129.1c78627
When I switched to the 7zip file and after many more attempts it finally downloaded. The exe link never worked.
I don't know if this is a security thing or a failed server but it is not a good way to distribute software either way.
If you are receiving the Access Denied error then you need to set the cookie to access a trial on our server. Per the directions on Prodesigntools.com which were also reposted in message #14 you need to initiate a download prior to trying one of the direct download links. If you don't have the cookie set you will be unable to initiate the download.
I did just test it and I was able to initiate a download for both File 1 and File 2 of InDesign CS6. I was on my home network utilizing Internet Explorer 8 under Windows 7 64-bit.
After jumping through all the hoops in the instructions yet again with Internet Explorer 8, it gives me the same 1.2 MB corrupt file as I get in Chrome, except it names the file "InDesign_8_LS16" whereas Chrome names it "InDesign_8_LS16.exe" by default.
HTTP/1.1 200 OK
Server: Apache
ETag: "b7ac2b83a81c176dd873f2f5a3a195ae:1335588761"
Content-MD5: t6wrg6gcF23Yc/L1o6GVrg==
Last-Modified: Mon, 16 Apr 2012 11:27:43 GMT
Accept-Ranges: bytes
Content-Length: 1268504
Content-Type: application/octet-stream
Date: Tue, 24 Jul 2012 22:29:53 GMT
Connection: keep-alive
As you can see, the problem is not on my end. The server isn't even sending the correct response header.
Miqrogroove, If you dont mind me asking, Are you doing this while you are signed into Adobe.com
The ideal way to do it is to log in to adobe.com,
Sign In,
Initiate any products downlaod by clicking on try and Eventually "Dowload Now"
You can retry this link by replacing "xx" by "tt" in "hxxp" below -
hxxp://trials2.adobe.com/AdobeProducts/IDSN/8/win32/InDesign_8_LS16.ex e
hxxp://trials2.adobe.com/AdobeProducts/IDSN/8/win32/InDesign_8_LS16.7z
By the way, since it isn't mentioned yet on those pages, I guess I should talk about it :
Those files are also downloadable from Adobe's public FTP server ( ftp://ftp.adobe.com/pub/adobe/cs6/downloads/ ), using either a "normal" Internet browser or, better yet, a FTP client (such as FileZilla or CyberDuck), which allows resuming of downloads in case they get interrupted.
In addition, this method doesn't even require to log in with a specific account on Adobe's website.
Thanks for posting about direct download. I was finally able to get the files downloaded, but they won't extract. I get to around 99% complete, and then it says that I either don't have enough room (I've got over a tb) or I don't have permission. If I try to extract the .7z file manually it says '~~~~~~ file is corrupt.' I've been trying to wrap my brain around this for days. What am I missing? T_T
Which version of which program did you use to attempt extracting the .7z file ?
If it was a different one, you should try 7-zip 9.20. However if it also says the file is corrupted, then, it must be. Such things may happen when downloading huge files : then you should try redownloading.
I was trying to download Indesign 5.5. Like others have mentioned before, I tried to initiate a download of another product by going to this link:
Click «here» to visit this page
However I'm getting a "Site Area Temporarily Unavailable" page so I cant go any further.
Anybody else getting this?
Hi Jeff,
Can you give us an update as to the status of your servers?
I've been trying to install CS6 using my Cloud account but for the past 2-3 days my download has stopped at 99% Downloaded. I also tried doing it using the direct links from http://prodesigntools.com and I'm getting that same issue 99% and download stops.
Thank you!
They have been back up and functioning properly since approximately 5 P.M. PDT on Friday. You likely are facing a different issue Appwebllc. Please feel free to post a thread with the details of your difficulties to the Creative Cloud Download & Install FAQ forum - http://forums.adobe.com/community/download_install_setup/creative_clou d_faq.
Hey Guys, I've tried the direct download links several times and they are not working on my computer. I've just noticed that File two of CS6 Master Collection is a .txt file, is that right? I have had the 101 error using the assistant, also had parts missing error from the direct download, please help...!!
Hello there :]
Did you try using a FTP client like I had suggested here ?
can anyone confirm the Adobe Web Premium CS5.5 English Mac DMG downloads successfully on this third party website?
I have tried downloading it over 10 times for the past 2 weeks, and it always "completes" at exactly 2.15 GB (when its supposed to be 4GB)
This is getting incredibly frustrating, why is Adobe relying on prodesigntools, a third part website, to host their previous versions? That is not very professional.
I've tried on different networks, different browsers, ethernet, everything. it fails at exactly 2.15GB each time, very suspicious that its on their end.
Where can we just get our CS5.5 downloaded (from ADOBE servers) which we paid money for?
Please, help!
Prodesigntools is not hosting the files they are giving instructions on how to reach the older version downloads. The install files themselves are still being download from Adobe's servers.
If you are facing difficulties with the download using the direct download instructions then it is likely your current Internet connection is causing the problem. If your network is managed please contact your I.T. department. If it is not then please contact your Internet Service provider as it appears you have a 2.15 gigabyte limit to download files.
