Dreamweaver CS4 and Windows 7 Compatibility
Jul 24, 2012 5:14 PM
When using CS4 (Dreamweaver and Fireworks) the "Properties" panel does not display correctly when running in Windows 7. The bottom half of panel is out of site no matter screen resolution and the input boxes "Title" etc are cutoff vertically.
Is this a compatibility issue, and if so, does anyone know of a work around?
Thanks for any help--Patrick
    Jul 24, 2012 6:06 PM   in reply to pwrentz
    Sorry, don't have your version.
    Are you sure you have expanded the PI ?
    Jul 24, 2012 6:34 PM   in reply to pwrentz
    I just tried CS4 on my Windows 7 Professional and I don't see the problems you are describing.
    If you click on the above image, you can see that everything is pretty much readable.  Are you sure you have got the correct drivers for your system?  For Dell System (I am using Dell Optiplex 760) you can download the drivers using your system tag number.
    Hope this helps you to pin point the problem.
    Jul 28, 2012 12:57 PM   in reply to pwrentz
    Make sure your system's Text-Size is 100% (default).
    To make the text on your screen smaller
    • Open Screen Resolution by clicking the Start button Picture of the Start button, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
    • Select  Smaller - 100% (default). This keeps text and other items at normal size.
    • Click Apply.
    • To see the change, close all of your programs and then log off of Windows. This change will take effect the next time you log on.
    Nancy O
    Jul 28, 2012 1:36 PM   in reply to pwrentz
    Try
    CS4 Property inspector fields truncated (Windows)
    http://forums.adobe.com/message/2032992
    Workaround
    ***Goto Control Panel > All Control Panel Items > Display
    ***Select on the left "Set custom text size (DPI)"
    **Set whatever scale percentage you want (DPI)
    ***Uncheck "Use Windows XP style DPI scaling"
    Click "OK"
    When you load up Dreamweaver you should see the whole Properties pane.
    In the case that you don't after changing that setting restart your computer and try again.
