Is There Anyway to Add Functionality to Quiz Buttons?
Jul 24, 2012 7:45 PM
I would like to add functionality to the quiz and it would be helpful, for example, to know what button was pressed. Can the quiz buttons be called with Advanced Actions (are they named)? It seems that the quiz functionality is pretty locked down from modifying (probably for good reason).
    Jul 24, 2012 7:54 PM   in reply to Kurrykid
    No. Quiz buttons do not have item names and cannot be referenced via advanced action.
    Jul 24, 2012 8:04 PM   in reply to Kurrykid
    What specific functionality are you trying to add to the quiz? It might still be possible to achieve via some other method.
    Jul 24, 2012 8:14 PM   in reply to Kurrykid
    This should still be possible.  You just need to set up your Conditional Advanced Action that gets executed On Slide Enter of the Quiz Results slide to also set a variable that tracks whether or not the audio has been played. (I'm assuming that you are SHOWing hidden objects with the Success or Fail audio attached, correct?)
    So, your Conditional Action also needs to look at this tracking variable to see if it has been set to indicate that the audio has already been played.  If not, it will proceed to SHOW the relevant object.  If the variable indicates this has already been done, then the Conditional Action does nothing.
    Jul 25, 2012 12:06 AM   in reply to Kurrykid
    Hi Kurrykid,
    I do not know about which audio you are talking, but there is at least one blog post in whichI explained how you avoid having the audio played when reentering a slide. For the moment Posterous is down, cannot send you the link but it is a recent post "Audio objects, control them". I showed the same feature in an older one: "Playtime with Audio and Widgets". And I suppose now you were referring to my Question slide blog posts.
    BTW: in Captivate 6 shape buttons can be used on Question slides, hope to find time to blog about them but it is so busy here.
    Lilybiri
