3 minutes video need 6 hours Rendering...
Jul 24, 2012 10:59 AM
Tags: #problem #video #after #output #render #ram
Today i started to render a video clip which have at least 20 videos with green screen keygen and a lot of effects like smoke, color correction etc. The video is 3 minutes and to render it i need 6 hours... Is this normal, i have to change some settings or i need to upgrade my computer? My computer is Intel Core i3, Graphic Card: GT440, 8GB Ram.
    Jul 24, 2012 11:02 AM   in reply to Triprosopos
    Are you working in HD?  Seems like if there's lots of effects, keying smoke and color correction that it could easily take 6 hours.  We need more information to give more detailed feedback though.
    Please provide answers to the questions listed here: "FAQ: What information should I provide when asking a question on this forum?"
    Jul 24, 2012 11:25 AM   in reply to BenMarkus
    We need a lot more information about your project to make any reasonable assessment of the time required. I've had keying projects that would render at one frame a second, and keying projects that took 10 to 15 minutes per frame. It just depends on what you're trying to do.
    Jul 24, 2012 12:57 PM   in reply to Triprosopos
    Yeah I've had projects where sections have taken that long per frame especially if there's tons of lights and 3D layers.  If you're running AE CS5 there's a useful script for background rendering that gives you the time taken per frame so you can have a better estimate of the full render time.  Check it out. http://www.andrewandoru.com/2010/03/17/labs-aerender/  It's just a droplet so you don't even have to open AE and that might help speed up the full render time.
    Jul 24, 2012 3:23 PM   in reply to Triprosopos
    6 hours is a normal time for a project with keying and lots of effects. I had a project that took nearly 14 hours to render once. Intel Core i3 is also not the best processor, so upgrading it would minimize the render time.
    Jul 24, 2012 10:50 PM   in reply to Triprosopos
    As the others said, it's perfectly normal. Sometimes even 10 second stuff can render for 2 hours. In your case it's probably the footage I/O in combination with the not so powerful CPU that makes things slow. I'm sure on anotehr system it would render in half that time...
    Mylenium
