Matching quiz - Captivate 6
Jul 24, 2012 10:59 PM
Tags: #problem #error #button #captivate #quiz #6 #questions #advanced_actions #lms #matching
This is my first project on captivate and i'm struggling with the matching quiz section of my project.
The issue is that when i publish or preview the quiz section of my project, if i answer the matching quiz correctly then it shows that yiur answer is correct. but i want to add an advance feedback giving an explanation when the answer is incorrect.
I couldn't locate an option for advance feedback in the matchting quiz slide. So, i tried adding the feedback in the "incomplete" button, which comes along with the correct button.
But it doesn't work in my case.
So, for the correct answer, it shows the green button.. showing that your answer is correct. But, for an incorrect ansswer.. it simply moves on the the next slide.
Looking forward for help.
    Jul 24, 2012 11:17 PM   in reply to krimon02
    Check that your quiz slide has failure level set to 1 or more. This should mean that you see a Fail caption if the answer is incorrect.
    The matching quiz template has no Advanced Answer option. That only applies to the multiple choice radio button wiz question type.
    Jul 25, 2012 12:16 AM   in reply to krimon02
    Sorry but I've never seen that specific problem.  Can you include some screenshots to show exactly what you are seeing?
    Jul 25, 2012 12:42 AM   in reply to krimon02
    If your issue is that the playbar is disabled during pretest questions, I think you will find that Nimmy has already answered that question on the other post as follows:
      "Do you have any Pretest questions inserted in your project? Inserting a Pretest question disables play bar options in Skin editor as it is not supported for a branch aware course."
    You said that pretest was disabling the Skin Editor of your project.  I took that to mean that you could not open the Skin Editor.  But it now sounds like your issue is more connected with the fact that you are prevented from setting a playbar to be used in the pretest. Was that the issue you were referring to?  If so, it sounds like Captivate 6 is designed to work that way.  So I don't have any way to change this.
