how can i center objects to the center of the page? i.e. all the centers should overlap with the center of the page?
If you go to Window>Object and Layout>Align, you can align objects to each other (selection), but also to the margin, spread, or page.
okay thnks
hey , how can i create shortcut for this?
The Usual Way: InDesign Help: Customize menus and keyboard shortcuts
Not every single command inside panels can be assigned a shortcut to but these 32 are available:
Product area : Object Editing
Horizontal Align Centre --- [none defined]
Horizontal Align Left --- [none defined]
Horizontal Align Right --- [none defined]
Horizontal Distribute Centre --- [none defined]
Horizontal Distribute Left --- [none defined]
Horizontal Distribute Right --- [none defined]
Horizontal Distribute Space --- [none defined]
Horizontal Margin Align Centre --- [none defined]
Horizontal Margin Align Left --- [none defined]
Horizontal Margin Align Right --- [none defined]
Horizontal Page Align Centre --- [none defined]
Horizontal Page Align Left --- [none defined]
Horizontal Page Align Right --- [none defined]
Horizontal Spread Align Centre --- [none defined]
Horizontal Spread Align Left --- [none defined]
Horizontal Spread Align Right --- [none defined]
Vertical Align Bottom --- [none defined]
Vertical Align Centre --- [none defined]
Vertical Align Top --- [none defined]
Vertical Distribute Bottom --- [none defined]
Vertical Distribute Centre --- [none defined]
Vertical Distribute Space --- [none defined]
Vertical Distribute Top --- [none defined]
Vertical Margin Align Bottom --- [none defined]
Vertical Margin Align Centre --- [none defined]
Vertical Margin Align Top --- [none defined]
Vertical Page Align Bottom --- [none defined]
Vertical Page Align Centre --- [none defined]
Vertical Page Align Top --- [none defined]
Vertical Spread Align Bottom --- [none defined]
Vertical Spread Align Centre --- [none defined]
Vertical Spread Align Top --- [none defined]
oh this was the list. thanks
