Index of array based on value
Jul 24, 2012 12:47 AM
Is there any inbuilt method to get the index of a \n array by its value (in JSX). It seems that indexOf doesn't work here as in javascript..
    Jul 24, 2012 12:50 AM   in reply to Shadowfax
    nope!
    i use this:
    Array.prototype.findIndex = function (value)
              var ctr = "";
              for (var i = 0; i < this.length; i++)
                        // use === to check for Matches. ie., identical (===), ;
                        if (this[i] == value)
                                  return i;
              return ctr;
    don't know from who i got this snippet, but lots and lots of thanks
    Jul 25, 2012 12:21 AM   in reply to Shadowfax
    JSX is based on an older version of ECMAScript. indexOf did not used to exist for Arrays.
    Here's an implementation that's equivalent to the javascript version:
    Array.prototype.indexOf = function (elem, fromIndex){
        fromIndex = fromIndex || 0;
        for(var i = fromIndex; i < this.length; i++){
            if(this[i] == elem){
                return i;
        return -1;
    There's a problem with Vamitul's version in that it returns a blank string if the index is not found, but it returns a number if it is. That makes it difficult to determine if the index is found or not. With the standard implementation you test for index < 0 to determine if the element is not found.
    Harbs
    Jul 25, 2012 12:30 AM   in reply to Harbs.
    Here's a more robust version which supports negative indices as well:
        fromIndex = Number(fromIndex) || 0;
        var len = this.length;
        if (fromIndex < 0){
            fromIndex += len;
        for(var i=fromIndex;i<this.length;i++){
                return i;
        return -1;
    Jul 25, 2012 3:59 AM   in reply to Shadowfax
    FWIW, here's the implementation recommended by Mozilla (which has more robust error checking) :
    if (!Array.prototype.indexOf) {
        Array.prototype.indexOf = function (searchElement /*, fromIndex */ ) {
            "use strict";
            if (this == null) {
                throw new TypeError();
            var t = Object(this);
            var len = t.length >>> 0;
            if (len === 0) {
                return -1;
            var n = 0;
            if (arguments.length > 0) {
                n = Number(arguments[1]);
                if (n != n) { // shortcut for verifying if it's NaN
                    n = 0;
                } else if (n != 0 && n != Infinity && n != -Infinity) {
                    n = (n > 0 || -1) * Math.floor(Math.abs(n));
            if (n >= len) {
                return -1;
            var k = n >= 0 ? n : Math.max(len - Math.abs(n), 0);
            for (; k < len; k++) {
                if (k in t && t[k] === searchElement) {
                    return k;
            return -1;
