Hi...
Am looking to align several stars (five pointed ones) centrally... (problem is the horizontal alignment). Question is, how does one go about it?
I've tried / know the following:
1. The bounding box is not 'related' to the centre of the star - so have gone the route of manually shifting the centre. Duplicating and resizing the star... it doesn't align on the horizontal.
2. Have tried not shifting the centre. Same result as 1. above
3. Have tried the Transform route, created multiple stars, expanded and ungrouped. Done with both the manually adjusted centre as well as the default centre. Same as 1. above
4. Have tried creating a circle and aligning the stars to that... no luck
In all cases the smaller copies seem to ride upwards... meaning that the top edges are closer to each other and the bottom edges are gapped more.
Important point is copies... the original aligns fine to a circle. The copies don't.
Yes, it's possible to grab the centre points and align them but surely there must be an 'automatic' way?
BTW, have been trying this only with a 5-pointed star - as in the US flag. I doubt the problem exists in a star with an even number of points.
Here you hit the nail on the head. So what you have to do is to find the star's geometrical centre like this (use Smart Guides to help):
Using the place where the lines cross as your centre, draw a rectangle larger (higher) than the star's bounding box, colour it None and group it with the star. Delete the two lines. Now you can align automatically.
Here's the way i do it...
1. Create star this is the star i'm talking about:
2. Copy it.
3. Delete the outer nodes, retaining only the five inner ones
4. Using 'Align to selection, align the vertical and horizontal axes so that you see only one node.
5. Delete four nodes, retaining only one
6. Paste in front - Control F
7 Select all and create a compound path
You now also have a star with a geometrical centre from which, you can now draw a circle that touches all points perfectly. However, duplicating and reducing or increasing the size of the star copy/ies does not line up the centres... That's the problem.
Hi Shunith, long time no see.
A silly and simple way of doing the first part:
1) Copy the Star to the front,
2) Object>Path>Average (this will give you 10 Anchor Points on top of one another at the centre),
3) Shift+Alt/Option+Drag with the Rectangle (or Ellipse) Tool from the centre (where the Smart Guides say anchor point) to get the larger square (or circle),
4) Delete the averaged path from 2).
And what Steve said.
Hi Jacob... yup... long tome. Hope all's well?
Jacob/ Steve.... Sorry, perhaps my fault for not explaining properly... left and right, horizontal is not a problem... it's the top and bottom - vertical alignment that goes off...
As you can see, the circle sits perfectly. The square is off. Now, i'm not looking at squares or circles at the moment. I'm just trying to do multiple copies of the star in descending or ascending sizes. Can't get them to centralise automatically. Have to do them manually. That is on the top-bottom or vertical alignment...
See what i mean?
Shunith,
After the coldest, wettest, cloudiest, and most thunderful, June anyone can remember and a cool start of July, now it fianlly seems to be summer here (harvest is/will be late and the tallest maize round here is about waist high).
With the star and circle (or square) grouped, I can reduce/enlarge the size flawlessly; with the circle I can also see that the centres coincide when I select all.
So I suspect something else is happening.
You do have Align to Pixel Grid unticked, no?
Hi, Shunith (and Steve and Jacob),
You can also generate the circle with Sato Hiroyuki's Circumcircle script:
http://park12.wakwak.com/~shp/lc/et/en_aics_script.html#circumcircle
As far as I know it works on all regular polygons and all regular star polygons.
Peter
Edit: Actually, the star Steve shows fits neither definition as I understand them. Maybe the script works on all equilateral shapes?
