I have created a table with an html dataset to display class schedules:
http://www.units.muohio.edu/lifelonglearning/ilr/fall2012working.html
Source dataset:
http://www.units.muohio.edu/lifelonglearning/ilr/fall2012-dataset.html
Is there a way to add a link so that when {course} is selected {description} is displayed?
One way to do this is to have a window pop-up when clicking on the course.
1.For the repeat region add spry:setrow ="ds1fall2012ilr" as in
<tr spry:repeat="ds1fall2012ilr" spry:setrow="ds1fall2012ilr" spry:odd="odd" spry:even="even" spry:hover="hover" spry:select="select">
2. Create a spry detail-region after the spry region as in
</table>
</div>
<div id="apDiv1" spry:detailregion="ds1fall2012ilr">
<div>{Description}</div>
<div><input name="" value="close" type="button" onclick="MM_showHideLayers('apDiv1','','hide')" /></div>
</div>
I have added an ID to the detail-region, placed the description and a button with an onclick event.
3. Now we need a few style rules for our detail-region as per
#apDiv1 {
position: absolute;
left: 122px;
top: 1400px;
width: 761px;
height: 341px;
z-index: 1;
background: #CCC;
visibility: hidden;
padding: 20px;
This will absolutely position the detail-region and hide it to start with.
4. When we click on the course we want the detail-region to show as in
<td onfocus="MM_showHideLayers('apDiv1','','show')">{Course}</td>
5. And lastly, a bit of JS that will handle our events
function MM_showHideLayers() { //v9.0
var i,p,v,obj,args=MM_showHideLayers.arguments;
for (i=0; i<(args.length-2); i+=3)
with (document) if (getElementById && ((obj=getElementById(args[i]))!=null)) { v=args[i+2];
if (obj.style) { obj=obj.style; v=(v=='show')?'visible':(v=='hide')?'hidden':v; }
obj.visibility=v; }
All of the above has been done using DW. The apDiv1 was drawn using Draw AP Div feature. The onclick events and JS were done in the Behaviours panel.
This is a very crude model of what can be done. You might like to have a look at http://linecraft.com/spry-pop-up-dialog/extension.php for a proper pop-up or use one of the light boxes. The example is only limited by your imagination.
Gramps
This is exactly what I wanted to do... however I don't think I have the coding correct. True confession - am a designer, not a programmer... so I REALLY appreciate your help. Can you take a look and see what I have wrong?
The link is correct - when you click on course the description appears - but below it. It doesn't "pop-up."
The updated files have been posted to the web. http://www.units.muohio.edu/lifelonglearning/ilr/fall2012working.html
I had looked at the linecraft product before I got to the point of posting here. It does look like what I need, however I am unsure about how to link it to the data set to populate the pop ups. Am hoping after we work through what you have given me I will understand how to set it up.
THANKS! - you rock!
A couple of additions/changes need to be made; some of the changes are as a result of my hastily made errors.
1. Underneath line #8 add the following highlighted
<style type="text/css">
.style8 {color: #EEEEEE}
#apDiv1 {
position: absolute;
left: 122px;
top: 600px;
width: 761px;
height: 341px;
z-index: 1;
background: #CCC;
visibility: hidden;
padding: 20px;
</style>
2. In line #125 change onfocus to onclick as in
<tr spry:repeat="ds1fall2012ilr" spry:setrow="ds1fall2012ilr" spry:odd="odd" spry:even="even" spry:hover="datahover" spry:select="dataselect">
<td>{Day}</td>
<td>{Time}</td>
<td>{Weeks}</td>
<td>{Begins}</td>
<td onclick="MM_showHideLayers('apDiv1','','show')">{Course}</td>
<td>{Oxford}</td>
<td>{Fairfield}</td>
<td>{Hamilton}</td>
<td>{West_Chester}</td>
<td>{Other}</td>
</tr>
That should do it.
Gramps
Place the cursor on line #122 of your document, then add the Spry Pop-up Dialog. You may get a warning issued by DW which you can ignore.
What this has done is
1. inserted links to the JS and CSS files in the head section of the document
2. placed a constructor for the pop-up near the bottom of the document
3. created the markup for the pop-up
4. created a clickable link to activate the pop-up
All we need to do now is to
1. change the pop-up to suit us as per
<div id="spryPopupDialog1" class="popupContainer" spry:detailregion="ds1fall2012ilr">
<div class="popupBox">
<div align="right" class="popupBar"> <a class="popupClose" href="javascript:;" onclick="spryPopupDialog1.displayPopupDialog(false);">-</a>
<div class="popupTitle">POPUP DIALOG TITLE</div>
</div>
<div class="popupContent">{Description}</div>
</div>
</div>
2. cut the link on line #122 and place it in the table cell as per
<td><a href="javascript:;" onclick="spryPopupDialog1.displayPopupDialog(true);">{Course}</a></td>
you will have noticed that the onclick event that we put there originally, has been removed
3. remove other remnants of the detail region as in
</div>
and
obj.visibility=v; }
These are no longer needed.
4. test the page in your favourite browser.
Gramps
Still waiting to hear back from Alex - but I did remove the fade effect - and it didn't help.
IE 7 on a PC gives an error and only shows the content holders.
In Dreamweaver it gives the compatiblity issues as:
Line 62 Expanding Box Problem
Line 103 Expanding Box Problem
Any content that does not fit in a fixed-width or -height box causes the box to expand to fit the content rather than letting the content overflow.
Gramps,
Alex came up with the solution - thought you would want to know - it was the load order of the .js file.
Move this line right after the <head> tag
<script src="../SpryAssets/SpryPopupDialog.js" type="text/javascript"></script>
so it looks like this:
<head>
Worked like a charm!
Thank you for your feedback, I shall certainly keep this in mind.
Have a look at his other products, like the Spry Utilities extension http://www.linecraft.com/, and service bar none!
Gramps
Gramps, there is one more bug that needs to be worked out of this page before it can be implemented.
NEW LINK - http://www.units.muohio.edu/lifelonglearning/ilr/schedule.html
In IE 7 or 8 when you click on one title it operates correctly, opens the description, then you can close it. When you open the second - looks perfect... but then it freezes the pop up frame. You cannot close it without refreshing the browser screen.
Fingers are crossed that you have an idea for this one.
THANKS!
Kim
This is the error message
SCRIPT5007: Unable to get value of the property 'filter': object is null or undefined
SpryPopupDialog.js, line 447 character 3
and this is the affected script
if (Spry.is.ie)
var filter = this.popupBox.currentStyle.filter.replace(/alpha\s*\(\s*opacity\s*=\s *[0-9\.]{1,3}\)/, '');
this.popupBox.style.filter = filter+"alpha(opacity=" + parseInt(ht * 100, 10) + ")";
It looks like friend Alex needs to be involved.
Gramps
Yes indeed - Alex solved it - and it was a fairly simple fix. Will share here for other's edification ![]()
Changed from this:
<div id="spryPopupDialog1" class="popupContainer"spry:detailregion="ds1fall2012ilr">
<div align="right" class="popupBar"> <a class="popupClose" href="javascript:;" onclick="spryPopupDialog1.displayPopupDialog(false);">Click to close</a>
<div class="popupTitle">{Course}</div>
</div>
</div>
</div>
To this:
<div id="spryPopupDialog1" class="popupContainer">
<div class="popupTitle" spry:detailregion="ds1fall2012ilr">{Course}</div>
</div>
<div class="popupContent" spry:detailregion="ds1fall2012ilr">{Description}</div>
</div>
</div>
Apparently IE doesn’t like when the entire widget is inside the detail region.
