PS CS6 Scripted Pattern Fill Problem
Jul 25, 2012 6:26 AM
Has any one seen this before?
When i do a normal Fill with Pattern the pattern is the right colour, image (1)
But if i select Scripted Patterns Image (2) it always comes out with random colours.
    Jul 25, 2012 6:53 AM   in reply to jayjayuk3
    If you don’t want the effect why do you use Scripted Patterns?
    You could edit the Script … documentation at
    http://www.adobe.com/technology/projects/DecoScriptedPatternsInPhotosh op.html
    Jul 25, 2012 7:44 AM   in reply to jayjayuk3
    CS6 Defalt Scripted Patterns change the layout they should'nt change the colour.
    Who says so?
    You can read the documentation and edit the respective Scripts you want to change with ExtendScript Toolkit.
    I haven’t looked thoroughly into Scripted Patterns yet, but removing the color randomization should not be too hard.
  • JJMack
    Jan 9, 2006
    Jul 25, 2012 1:34 PM   in reply to jayjayuk3
    There is also a scripted UI for these scripts http://uebelephoto.com/CS6_Fill.html
    Scripted Fill UI v 1.2 for Photoshop CS6
    This script creates a User Interface for changing the variables in Photoshop CS6's new scripted fills, so the average user does not have to edit Photoshop's fill scripts. There is a readme file included with the zip download that describes the script in more detail and how to use it. This script is free and can be modified for your own use, but it can not be modified for resale.
    This script is a work in progress and there are some bugs with it, which I will attempt to fix as time permits.
    Download Script Updated 5/1/2012
    I do not use it nor do I understand its UI
