1 indd file for smartphone, tablet devices
Jul 25, 2012 8:08 AM
i posted this question in indesign forum but maybe here's the better place to ask this question.
i've gone to this DPS yet. as Indesign can create an app, just wonder if i need to create a different documents for different devices.
i want to have the same master document that can target different devices. however, resolution is vary in different devices. that's why i want to confirm.
anyone know?
thanks.
    Jul 25, 2012 8:52 AM   in reply to commonguy101
    That all boil down to what you are willing to do.
    Yes you need different Documents for the different Tablets as DPS does not yet support the liquid layout feature in CS6
    So if you were designing for a 7" you would design a document tailored to that, and if for the iPad then a seperate document tailored for that
    Unless you're happy to have all your iPad pages a smoothscroll (Longer than the height of the screen) and integrate the layouts so they work seamlessly
    Or you could learn HTML and flow your content in.... but I wouldn't know where to start with that one!
    Hope this helps!
    Jul 25, 2012 11:35 AM   in reply to tim.hughes
    A small correction to the above: you can use the CS6 alternate layouts feature to create one InDesign document that contains layouts for different devices. You can also use the liquid page rules feature in InDesign to help automate the generation of that second device layout contained in the same file.
    This is a great workflow enhancement and for many types of content will really reduce the time required to create two different devices.
    What we don't currently support is the ability to have one layout that runs on multiple devices and adapts on the fly (at device render time) to the different screen size.
    Neil
    Jul 25, 2012 11:42 AM   in reply to Neil Enns - Adobe
    Interesting Neil, you say that Liquid Layouts are now supported through the import process in the folio builder?
    Jul 25, 2012 11:44 AM   in reply to tim.hughes
    No, unfortunately. Documents that contain alternate layouts still cannot be imported via Folio Builder. You have to manually add them.
    Neil
    Jul 25, 2012 11:45 AM   in reply to Neil Enns - Adobe
    Ahhh that's what I meant in my first response - that it wasn't possible to import all these liquid articles
    But maybe in the future!
    Thanks for the clarification though!
    Tim
    Jul 25, 2012 11:46 AM   in reply to tim.hughes
    That’s not what he said.
    You can use the liquid layout features to create alternate layouts. The end goal of all of this is to have one liquid layout that will conform to all devices.
    Bob
    Jul 25, 2012 11:48 AM   in reply to Bob Levine
    Just confirming the possibilities Bob
    Thanks for your input.
    Tim
    Jul 25, 2012 1:01 PM   in reply to commonguy101
    If you use alternate layouts in CS6 the content, by default, is connected across layouts. This means if you update the text on the master layout (the first one in the file) that will be reflected as an out-of-date link in the links panel for the other device layouts.
    Alternate layouts and liquid page rules work hand-in-hand. If you choose you can use liquid page rules to speed up the process of laying out your alternate layouts. You are not required, however, to do so. If you like you can just generate an alternate layout without any page rules applied. You'll get a layout that doesn't fit at all on the new page, but can then move the elements around manually to get your desired design.
    Neil
