Hello there. I'm trying to give our school newspaper's webpage an overhaul using BC (without dreamweaver) and have run into two problems.
First off, every time I set one of my pages as the start page, it doesn't stick. I've named it home, hit start page, base url still says no default start page. I've tried creating a new page called index, and it still doesn't work.
Base URL: http://bellmagazine.businesscatalyst.com/
Desired Home page: http://bellmagazine.businesscatalyst.com/index
My second problem is visible on both links. Above and below the content are numerous links and text about BC, along with a floating "report abuse" button. I cannot find these in either the design or html tabs, and would like to remove them from my site. How do I accomplish this?
I've checked your site and was able to set the domain's start page to reference the /home page as required.
This is appears working at the moment.
In regards to the "abuse report" button that will remain visible only in trial. Once a site is upgraded this button will be removed automatically.
Kind regards,
-Sidney
You do not need DW to work with BC. We have an admin interface to allow you to edit your site through. DW is just an extension that can be used when editing your BC site.
For various site plan please see below.
- http://www.adobe.com/products/business-catalyst/buying-guide-subscript ions.html
Hope this helps!
-Sidney
