Hi MikeJRW,
For a 3D scene, you have a few variables that can be moved in order to composite the 3D elements into a 2D background image. There's the "Ground Plane" which defines a flat surface where shadows and reflections display, there's lights which can control the direction and size of shadows, there's the object's location in space (not always resting on the Ground Plane), and then there's the camera view and attributes which defines perspective and field of view.
Most basically, you want to adjust the camera view (click on the canvas with the Move tool selected, until you see an orange outline around the document view) in order to move the ground plane around relative to what you're viewing of the background image. There are options for how the camera moves in the tool options bar, upper far right.
To get everything aligned so that the composite looks realistic can be tricky and time consuming. In Ps CS6, we've added a few things to make it easier then in earlier versions. The first thing you might look at trying to do is defining the background image's horizon and perspective using the Vanishing Point filter (search Vanishing Point filter for usage instructions). Now, assuming you have a Ps generated 3D extrusion from a vector path, export that layer out as a Collada (.dae) file, so it can be imported into the background image file. To import the 3D mesh file go to 3D > New 3D Layer From File... and the 3D mesh should align much better with the perspective of the background image. You might need to adjust the scale of the 3D object.
You also want to adjust the lighting direction to match that of the background image, so the shadows are in the same direction and length. You can do this by selecting the lights in the 3D panel to get a light control widget showing on-screen, or by Shift+ click directly on the shadow and then dragging it around.
I did a real quick overview here, and there are many step by step tutorials that go into more detail. I hope this helped.
regards,
steve
"click on the canvas with the Move tool selected, until you see an orange outline around the document view" When I click on the canvas I get either a blue outline (environment selected) or yellow (3D camera) around the documnet view. Don't see a "tool options bar". There is the propeties panel, and a tool presets panel. Tried the vanishing point filter but it doesn't seem to work, it's not affecting the current ground plane.
I basically just need to move the horizon line of the current ground plane down to about a third above the bottom of the page so it matches the scenery image, this should be simple!!!
...Actually maybe not, need to lower the ground plane as I said before not neccessarily horizon line I guess.
Message was edited by: MikeJRW
Okay I figured it out! You can click on the canvas until you get the yellow outline and 3D camera properties panel, then click on the coordinates icon in that panel. Increase the Y value in the move column and then the angle. Sharon thanks for showing me where that drag tool is, guess that does the same but seems tricky to adjust that way. Thanks SG for all that info. I'm on strong meds for allergies haha so kind of out of it, also went from CS4 to CS6 just a couple days ago lol. This new PS 3D stuff is very very cool, it's outragious that I just pulled off what I did, looks pretty darn good. Can't share it for now, but thanks very much guys. It's basically a stage lit with spotlights with a 3D marble version of a logo floating above it. Used a blending mode so the rays of light passed in front, and adjusted lighting angles to match.
This question is related to Photoshop CS6 3D capabilities.
I am a designer that has several product package designs as flat 2D print Illustrator files. I want to use the panels to create realistic 3D mock-ups. Ones that can be rotated etc. I have looked everywhere but find very little tutorials for this at all and the software is not so comprehensive that I am able to figure it out on my own. Can anyone help?
I am new to using 3D in photoshop but not new to Photoshop, Adobe or 3D basics.
