I know in photoshop you can make shapes with the pen tool and then covert them into a selection path.
I was wondering if there is such similar feature in Illustrator
For example with the picture I posted here, what I want to do is be able to select the objects that are in contact with the black object on top without having to individually select them or use the "lasso" tool
It would make things easier with a "Select all objects under or above" option, theres only the "Select next object under or above"
Djxyz0 wrote:
Thanks but even with that it would be hard, lets say I want to select one diagnal road? I'd have to have a steady hand, and it'll be even harder If I had more and smaller squares
what do you mean? don't relay on your hands, use the line tool or the pen, draw a straight line, run the script.
the script works exactly the way you originally asked, you draw a path, with the pen if you want, then run the script and everything under this path of yours will get selected.
