snap-on requested when reinstalled CS2 ID to read files created therewith
Jul 25, 2012 10:32 AM
missing plugins 1.jpgmissing plugins 2.jpgI re-installed my ancient CS2 Indesign on a Windows 7 computer to read seven year old files created therewith.  When I attempt to open a file I'm prompted that a variety of snap-ons are missing.  I've copied screen shots of the prompts below.  Anyone know where I can I find these snap-ons?  I only installed CS2 Indesign.  If I'd have installed everything, would that have picked up the missing snap-ons? The second image below is a scroll view from which I've only copied the top of the scroll.
    Jul 25, 2012 10:39 AM   in reply to cyberbaffled
    I answered you in the post. Those are NOT CS2 files.
    Bob
    Jul 25, 2012 3:49 PM   in reply to cyberbaffled
    As Bob has already said, that error mans the files were saved in a leter version of InDesign, at least CS4. Yoou can use this script to tell you what version: Adobe Forums: [Ann] Identify Your InDesign File
    Jul 25, 2012 3:54 PM   in reply to cyberbaffled
    What Bob means is that those files that the files you think are CS2 files have been resaved as a CS4 file at some time.
    Jul 25, 2012 5:10 PM   in reply to cyberbaffled
    Seriously, do you even bother to read the responses here or do you just want to keep asking the same question over and over again?
    Bob
    Jul 26, 2012 6:47 AM   in reply to cyberbaffled
    What versions of InDesign DO you have? This isn't necessarily a CS4 file, just at least that new. Has anyone else had access to these files?
    As far as backward compatibility, there is no page layout program I'm aware of that can open files from new versions of the application. Layout apps are a lot more complex than MS Word. Adobe does provide a method for converting newer files for use in older versions -- exporting to .idml for versions CS4 through CS6, but for anything earlier you must open in CS4 and export to .inx, then open that in CS3 and export again to .inx and so forth, back to CS. There is no method to convert a file to readability in Version 2.0 or earlier. Be warned, though, that back-porting files can be pretty iffy. New features are lost, and text is practically guaranteed to reflow.
    Jul 26, 2012 10:55 AM   in reply to cyberbaffled
    What happens if you just use File>Open on the .inx file from CS1 in CS5.5?
    Jul 26, 2012 10:59 AM   in reply to cyberbaffled
    > From CS 1 I've exported at least one of those files in inx format, hoping to open it in ID CS 2, but in the latter the xml import option is grayed-out.  So also it's grayed out in CS5.5.  So I'm stumped.
    That is not how one opens an .inx file. Simply use Open, as Larry says.
    It makes one wonder why "Import XML" is disabled, though -- usually you can import as much XML as you want, and it has nothing to do with you trying to target an .inx file (it'd try but then probably fail).
    Jul 26, 2012 11:04 AM   in reply to cyberbaffled
    I don't want to get into a long discussion about the pros and cons of a stripped down version of ID. That's not something that is likely to happen. ID is not targeted at business users who want a simple word-processor-like application, but rather at design professionals who want, and need all the features they can get.
    Back to the problem at hand. InDesign CS5.5 can open any .indd file created from Verison 1.0 (I think, but those are pretty rare) up to CS5.5 (which is version 7.5; CS was version 3, and CS2 is version 4, so the numbering is a little confusing to some people). IF you want to edit these in CS5.5 you can just use File > Open..., and the same command will open the inx files (in the same or any newer version than the one used to do the export) or any .idml files you might have. You don't need to import xml.
    My personal advice is that you should export .inx from the original version, then open that in CS5.5. It cleans up any minor corruption and forces all of the text to recompose with the new text engine. If you open the .indd files directly the text will not recompose until you click a text frame, and you can get some nasty surprises, and we see some reports of sudden file failure after legacy .indd files are edited in CS5 and later. If you do open the .indd files directly, you should export immediately to .idml, then open and resave that as a new .indd (DON'T overwrite the old one) and continue to edit the new file.
    Jul 26, 2012 11:06 AM   in reply to [Jongware]
    I suspect is has to do with there not being an open document. Can one import xml without a document into which it should go?
    Jul 26, 2012 12:25 PM   in reply to cyberbaffled
    Try exporting the file again.
    Jul 26, 2012 12:27 PM   in reply to cyberbaffled
    Did you EXPORT an INX file or just rename an INDD file?
    Bob
    Jul 26, 2012 2:05 PM   in reply to cyberbaffled
    Your posts would be easier to read if you heit the enter key every so often.
    It isn't clear, have you tried opent the file in CS5.5 and exporting to .idml BEFORE you do anything else?
    Jul 26, 2012 11:13 PM   in reply to cyberbaffled
    cyberbaffled wrote:
    …a file created in 2002 or thereabouts using ID CS 1 and archived; then reopened today in ID CS 1 reinstalled in a Windows 7 environment…
    One key point that you may not be considering is that when the document was created in 2002, it wasn't created using Windows 7. If you have an older computer with the OS you used in 2002, you may get different results. If you can, open the file in CS1, export it to INX, and then move that file to the Windows 7 CS5.5 machine.
    Also, it sounds like you are experiencing the forum through email (maybe with a smart phone), which makes it harder to follow the time line. If you use a web browser to come into the forum on your computer, it may be more clear who said what and when.
    Jul 27, 2012 4:24 AM   in reply to Michael Gianino
    Also of note is that no version of InDesign earlier than CS3 is supported in Windows 7. All bets are off with this combination.
    Bob
    Jul 27, 2012 5:35 AM   in reply to Bob Levine
    I never managed to get CS1 to install, even in the virtual machine.
    Do you still have an XP box? How does the file behave in CS1 on that?
