Hi Helper's,
I'm getting error on time of resizing image such as "Error #2030: End of file was encountered". I want to resize as per specified size. Code is written in Flash builder 4.5. Please find my code below and help me to correct.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
initialize="initNew()" xmlns:local="*">
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<fx:Script>
<![CDATA[
import mx.controls.Alert;
import mx.graphics.codec.JPEGEncoder;
private const image_path:String = "sample.jpeg";
private var loader:Loader;
private var request:URLRequest;
private var loadBD:BitmapData;
private var cropBD:BitmapData;
private var squareW: int = 75;
private var squareH: int = 100;
private function initNew():void
loader=new Loader();
request=new URLRequest(image_path);
loader.contentLoaderInfo.addEventListener(
Event.COMPLETE,onComplete);
loader.load(request);
private function onComplete(event:Event):void {
try
loadBD = Bitmap(event.currentTarget.content).bitmapData;
var bitmapData:BitmapData = new BitmapData(squareW, squareH, true, 0);
bitmapData.draw(loadBD);
//Getting error in this line
var ba:ByteArray = (new JPEGEncoder()).encodeByteArray(bitmapData.getPixels(new Rectangle(0, 0, squareH, squareH)), squareH, squareH, true);
ba.position = 0;
imgResized.source = ba;
catch(e:Error)
Alert.show(e.message);
</fx:Script>
<s:BorderContainer id="bcImage" width="75" height="100" maxWidth="59" borderWeight="1" borderColor="red">
<s:Image id="imgResized" width="100%" height="100%"/>
</s:BorderContainer>
</s:Application>
If anyone faced similar kind of problem?
Is there a specific reason why using a BitmapImage would not work for your use case? If you are worried about the overhead, I would take a look at the source and copy out the bits you need. One thing I noticed after looking at the source is that they do not use any kind of encoder to perform that functionality. Is there a specific reason you need this?
Thanks for your reply and happy to see you.
No reason, I got above code When I google it and changed accordinaly to meet req. My requirement is, server will be giving 400*350 (Byte array) size image. That one what to resize into 75*100 and apply it to image component. I'm fine with any approarch, however if the image size is less than 75*100, then should not stretch the image. I have tried with fillMode (BitmapFillMode.CLIP), scaleMode(BitmapScaleMode.LETTERBOX). Please update your concern on same.
Note: Plz ignore this maxWidth="59" property in BorderContainer property.
