Can CreatePDF produce print ready (CMYK) files?
No compression of images below 300dpi, etc
I guess this would be PDF/A-1b
I am running Word 2007 on Windows 7. I do have Acrobat, but the installation has suddenly broken (always produces 8.5" x 11") and I am thinking of Create PDF as a quick fix.
Hoping for a positive reply
Michael
Many would say that if you want a print ready file you need to work in a DTP application that directly supports CMYK, and that attempting to convert Word documents for this purpose isn't going to produce acceptable results...
PDF/A is not designed for print production at all: the A stands for archiving and says nothing about quality print.
PDF/X is designed for quality print but says nothing about image resolution; that's a separate decision, because each printer will have their own minimum (and maximum) they need.
Do you think I haven't tried that???
It turns out that the Word behaviour 'Scale to A4 / 8.5 x 11" ' had become inverted. Go figure, as they say.
I can't agree about not using the Create PDF icon, because I've read that printing to Adobe PDF reduces the image quality to 200dpi no matter what you select, and this does indeed seem to be the case, for instance in this forum post.
