RockChalk22
Overlay (2) 250 page pdfs
Jul 25, 2012 4:01 PM
I have (2) 250 page pdf files that I want to overlay one on top of the other. Is there a way to do this in Acrobat 9 Professional?
    Jul 26, 2012 5:21 AM   in reply to RockChalk22
    Depending on how you would like the pages to display on each other, you could use either Document > Background > Add/Replace or open the Layer navigation pane, select the flyout menu and select Import as Layer.
    Jul 26, 2012 6:24 AM   in reply to LoriAUC
    Sorry but that doesn't work in the way RockChalk22 wants - the OCG and background/watermark tools will only import a single page and replicate it across the pages of the active document, irrespective of how many pages are in the source file.
    You can do it with a console script, provided you know the two documents have the same page counts and the source file is in a known location:
    Paste this into the JS console (CMD-J or Ctrl-J), edit the filename, select it all and press ENTER:
    for (n=0;n<this.numPages;n++) {
        this.addWatermarkFromFile({
            cDIPath: "/C/myfolder/sourcefile.pdf",
            nSourcePage: n, nStart: n});
    For more options such as scaling and opacity, see the Acrobat JavaScript API documentation.
    Jul 26, 2012 7:01 AM   in reply to Dave Merchant
    Thanks Dave.
    Aug 20, 2012 3:05 AM   in reply to Dave Merchant
    Hello Dave M and others,
    This script was really useful. Is there a way to replace the ".addWatermarkFromFile"-part with ".addBackground.." ... and to specify that the background goes as the BOTTOM layer (behind all other page items)?
    Aug 20, 2012 4:24 AM   in reply to PrntScr
    There's no 'addBackground' method - instead you set the bOnTop parameter to false.
            nSourcePage: n, nStart: n, bOnTop: false});
