Spry Horizontal Menu Problem
Jul 17, 2012 9:32 PM
I switched to version 2 of the Spry Menubar due to sub-menu problems associated with iPads. Now I am having problems with sub-menus within IE8.  It is not possible to *quickly* scroll down the menu without the sub-menu disappearing.  Here is an example:
http://gerberanalytics.com/tennis/tennis_header_test.php
It works ok with CS6 in the design view, but not on the local test server or on the production server.  Any ideas?
Thanks in advance for your help.
    Jul 19, 2012 10:34 PM   in reply to Scott - Columbus, OH
    You got an .htaccess file that states the charset to be iso-8859-1, yet your document shows a charset of utf-8.
    Unfortunately, IE cannot cope with that, hence it goes into Quirks mode, or said differently, it uses the IE5 rendering engine.
    Gramps
    Jul 20, 2012 6:59 PM   in reply to Scott - Columbus, OH
    For some reason, IE goes into Quirks mode. That is the reason why your menu bar misbehaves in IE
    Have a look here http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fgerberanalyti cs.com%2Ftennis%2Ftennis_header_test.php
    Maybe if you fixed the above, IE will start to render properly.
    Gramps
    Jul 25, 2012 6:20 PM   in reply to Scott - Columbus, OH
    @Scott,
    I do not believe you.
    You have done nothing to rectify the situation that you yourself have created. Have a look at the result of what you have done to the markup. It has sent IE into a frenzy as in
    Let me tell you right now, installed properly, SpryMenuBar 2 does work in IE and does work with touch screens.
    If you had listened to what I have said, without getting on your high horse, you would have fixed your problem by now.
    Grumps.
    Jul 25, 2012 7:15 PM   in reply to Ben Pleysier
    To prove my point, have a look here http://pleysier.com.au/SpryMenuBar2, try it in IE7+ and in a touch screen device.
    Also have a look here http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fpleysier.com. au%2FSpryMenuBar2%2F
    Gramps
