I'm using Captivate 5.5 and trying to insert a graphic at the top of the TOC. When I do, the graphic is tiny. Is there anyway to make the area where the graphic fits any larger?
I'm afraid, you may not be able to increase the graphic dimension from that window and I would recommend rather than keeping it on TOC, use a Master Slide to put in your graphic and adjust its resolution as you like, apply your master slide to all the slides.
