Hello all!
Here is a picture of my problem, which shows the inserted symbol mid-sentence overlapping my top sentence text:
How do I fix this? THANK YOU so much in advance!
jessie ![]()
P.S. The symbol automatically flowed in when I imported my stuff from Word, so I did not insert this in FM. I'm in FM 10 with 32-bit OS.
Select the paragraph where the figure appears.
Open Paragraph Designer.
On the Basic tab, in the Indents and Spacing frame, deselect the "Fixed" check box.
Apply the change.
This increases the leading for the line. The other option is to resize the figure and its containing frame to fit the standard leading.
See Working with multiple languages in the Help.
FM has character map features to aid in entering non-keyboard glyphs, but it's probably easier to use the Windows Character Map.
Quick & Dirty:
This is not stable. If you Update All and revert to paragraph Default Font, the glyph may vanish.
More Elegant:
You can now insert this glyph anywhere you need it, irrespective of paragraph defaults and other Character Formats. If it does get damaged, just re-insert the variable in place.
