ToniChaffin
How do I make a Form Read Only
Apr 1, 2012 4:23 AM
Tags: #acrobat #forms #form #pdf_forms #acrobat-form #fillable
I am fairly new to the world of creating PDFs, and more specifically Forms. I have created a form with a number of text fields on it and have the form in the format I wish to use. I have added the ability to allow users to fill in the boxes and then save the PDF by using the 'Reader Extended PDF>Enable Forms Fillin & Save in Adobe Reader'.
What I don't want to happen is to allow the user to save over the master they are opening, I want them to be forced to 'Save as....'. Apart from making the file Read Only in Windows, which I assume will work, is there a way of forcing it to 'Save as....' with Acrobat Standard X or Reader?
Thanks in advance
    Apr 1, 2012 4:40 AM   in reply to ToniChaffin
    No, you can't enforce that, but you can set the file to be read-only (in
    the file's properties). Of course, any way can change that locally...
    Apr 1, 2012 5:22 PM   in reply to ToniChaffin
    For normal use on a web site, the RO would not be an issue since the file is saved locally before opening. However, it sounds like you are using a network drive and do not want folks to overwrite the original. In that case your solution is probably best.
    Jul 25, 2012 11:20 AM   in reply to Gilad D (try67)
    Please confirm: it is not possible to create a form (in Acrobat X) that automatically saves as a read-only PDF after being filled out by the user in Reader X.
    True or False?
    Thanks, Chris
    Jul 25, 2012 1:09 PM   in reply to Chris Fiset
    False.
    Jul 25, 2012 1:27 PM   in reply to Bernd Alheit
    Bernd:
    If you know of a way to automate saving as to read-only PDF status, please share.
    According to try67, "You can't enforce that [i.e., force the user to save as in read-only format], but you can set the file to be read-only (in the file's properties)".
    Also, after hours of trying, I am unsuccessful in making this happen, so I would be very interested in your method.
    Chris
    Jul 26, 2012 2:29 AM   in reply to Chris Fiset
    You can set the property of the form fields to read-only.
    Jul 26, 2012 9:52 AM   in reply to Bernd Alheit
    Can you please list the steps invovled to set the property of the form fields to read-only? Unfortunately, I'm not seeing any way to do this.
    If I click File/ Properties ... among the 6 tabs that appear (Description|Security|Fonts|Initial View|Custom|Advanced) -- I am not seeing an option to set the form fields to read only.
    (On the other hand, if you are referring to setting the *file's* properties (by right clicking on the file itself) yes, I can set it to read only. This however doesn't answer my original question -- which was: is there a way to automate an Adobe form to *automatically* save as a read-only document.)
    The reason I need this feature to be automated is because I am needing to create a form template that will be distributed to hundreds of users. Ideally, it would be set up to save as read-only and then emailed to its destination from within Adobe Reader X.
    Asking hundreds of users to manually right-click on the file's properties is not a solution -- as this is a very user-unfriendly approach.
    Chris
    Jul 26, 2012 1:12 PM   in reply to Chris Fiset
    Adobe Reader can't change file properties.
