Hi
I have been trying to get the internal server reporting to work in captivate 5.5 and captivate 6 with no luck
I have been searching google and these forum all day to find many post with the same problem and no solutions
i need to get it to work from a web server on hostgator i have both linux and windows hosting with them and nither work
firstly i Put internalServerReporting.php and internalserverread.php files on the root directory of the webserver
when i test i get
Warning: mkdir() [function.mkdir]: File exists in D:\InetPub\vhosts\fstudio.co.uk\httpdocs\captivate\internalServerRepor ting.php on line 35
Warning: mkdir() [function.mkdir]: File exists in D:\InetPub\vhosts\fstudio.co.uk\httpdocs\captivate\internalServerRepor ting.php on line 37
Warning: mkdir() [function.mkdir]: File exists in D:\InetPub\vhosts\fstudio.co.uk\httpdocs\captivate\internalServerRepor ting.php on line 39
Warning: mkdir() [function.mkdir]: File exists in D:\InetPub\vhosts\fstudio.co.uk\httpdocs\captivate\internalServerRepor ting.php on line 41
Warning: fopen(./CaptivateResults////////) [function.fopen]: failed to open stream: No such file or directory in D:\InetPub\vhosts\fstudio.co.uk\httpdocs\captivate\internalServerRepor ting.php on line 43
Warning: fclose(): supplied argument is not a valid stream resource in D:\InetPub\vhosts\fstudio.co.uk\httpdocs\captivate\internalServerRepor ting.php on line 45
Added the following to the internalserverread.php file after <?php:$filterArray = array(".","..",".DS_STORE",".svn");
and that dose nothing
In Captivate, changed quiz prefs to point to the Reporting.php file
Published captivate file to the root directory
Took captivate quiz and posted results with name and email
Looked into CaptivateResults folder and no directory structure and data were present
Opened Captivate Quiz Results Analyzer
Went to options >> preferences and added an internal server location
i have changed chmod permissions aswell to no avail
if i do it localy via wamp i get the xml but it wont open in quiz analyser un les i set it to my computer
linux specs
| Apache version | 2.2.22 |
| PHP version | 5.2.17 |
| MySQL version | 5.5.23-55 |
| Architecture | x86_64 |
| Operating system | linux |
please help
thanks in advance
Okhey, so to be honest, I haven't yet depolyed it on Linux, but I believe the process is more or less similar.
I would let you know what I tried and has been working for me on Windows.
1) Installed Wamp.
2) Placed the internalServerReporting.php and internalserverread.php files on the root directory of Wamp.
3) Booted my Wamp Service.
4) Configured my Project with the Server address as my localhost/IP wise.
5) Placed the Published project in a Folder in Root Drive (www folder)
6) appeared for the course from a remote machine, using http://IP/Folder/index.htm
7) Used Quiz Result analyzer to pull results.
When you say " In Captivate, changed quiz prefs to point to the Reporting.php file", I guess you are going wrong here, you need to point the Server name to Wamp Server Location.
Check this video and this should clear some doubts.
http://blogs.adobe.com/captivate/2010/08/reporting-the-quiz-results-to -a-local-server.html
http://tv.adobe.com/watch/publish-and-track-results/reporting-using-lm s-or-internal-server/
thanks!
Anjaneai
thanks for you Anjaneai for you quick replay got it working on my windows rig with wamp just needed to take a breath
still no joy on the linux server but progress has been made i have found that the file is createing the relivant directories and generating xml files
but when i try to use the quiz analyzer it now come up with no companies on this user account
however if i downloard the captivate resultsbfolder and use the browse from my computer option it works fine ??
if anyone can tell me how to get it to work with out the download that would be fantastic but if not at lease it kinda works which is good for now
thanks again
Hi ,
Glad that you got a start there.
Ok, I believe you have provided the Course, Department and Company name.
Now, when you sign in to Quiz Result Analyzer, Select the drop-down as from this computer, 'Browse' to the location where you have got you Captivate Result Folder, In my case, I used Wamp with Quiz Result Analyzer on same machine and I located the folder at C:\wamp\www\anjaneai\CaptivateResults
once, done Click on 'Generate Report' button, it would pull up the report for the seesions your users appeared for.
Anjaneai
